Better flowing intake for 5.7 w/Ecodiesel lower airbox
Ram7081
Hurricane 3.0
<deleted - found answer>
Ram7081
Hurricane 3.0
Free shipping promo? I saw there is one floating around. Thinking since its the 4th of July they'd have it on the site and I didn't see it. Can someone please post it or PM to me?
Thanks
cnitty
I like the feel of my pedal now with this mod and adding the AEM dry filter.
cityredneck
arlington, tx
i did this in the middle of july before a road trip and the truck did have better throttle response.
NoveskeFan
Historic Triangle area in VA
2017 Crew Cab Short Bed Copperhead Sport 4x4
I installed the lower airbox, inlet pipe and filter this evening. That filter is twice as thick as the stock 5.7 L filter.
My understanding is that you can still use the 5.7 filter. I wonder if the thicker Eco Diesel filter can cause issues or reduce airflow into the 5.7?
Hemi395
Hemi395
Cape Cod MA
The Ecodiesel/6.4 filter are the same PN and they flow more air than the 5.7 filter. The Ecodiesel has a turbo and needs more airflow than the 5.7 as well as the 6.4 because it's a bigger displacement motor.
The filters are the same outer dimensions so you can swap back and forth.
The EcoDiesel airfilter is the same part# used in the 6.4l Hemi, the thicker airfilter will flow more air and hold more dirt before it's clogged up.
Chickamauga, GA
Has anyone who has done this modification noticed improvements in fuel mileage? I wonder also if my exhaust would sound a little throatier under throttle.
kurek
Northwest
Why would it improve fuel mileage?
