BEWILDERED
Dave Haddon
Saskatoon SK. Canada
Disconnected battery to do a small light job and now there is no back up camera..cannot find any indication of back up camera anywherte not even an image in the aps. ANy ideas?
Dean2
Near Edmonton
It will be back after about 24 hours. Lots of featurea take quite a while to reload after battery is disconnected.
Let it sit for an hour Dave,odds are it'll all be back after it sits for a bit.
Tulecreeper
AZ - 83 Miles SW of the Geographical Center
Yep just found the answer on u tube..hold the two radio buttons for 10 sec..voila..camera indicator is back..yeah!
Is that how to disable it also? I've tried every way I can think of to turn off, disable, or bypass that camera because it's irritating and the only answer I found is to unplug it at the tailgate. But I can't do that or it will disable my tailgate lock also.
Jimmy07
If you just want to unplug the camera, so all you get is a blue screen when in reverse, simply disconnect the white connector at the tailgate plate (circled in red below). This will still allow the tailgate release switch and latches to work.
If you want to remove the backup camera feature as if it never existed, and there is no reaction on the radio screen when the truck is put into reverse, then you’ll use AlfaOBD to disable the backup camera feature.
Tulecreeper
Thanks, I'll try the connector thing. And yes, I would like to disable the screen coming on too, but every place I've looked - here, YouTube, etc. - says it can't be done even with the AlfaOBD. But, I have a piece of electrician's tape over the lens now and all I get is a black screen so I guess that's good enough. It's a shame, though, that RAM (and other manufacturers) seem to think everyone wants these nanny features that can't be disabled. The camera thing is a federal mandate that they have to install it, but there is no mandate that says we have to use it. It's the same with the horn honking thing when I get out and close the door with the fob in my pocket. It's irritating, I don't want it, but there is no way to disable it.
Jimmy07
Thanks, I'll try the connector thing. And yes, I would like to disable the screen coming on too, but every place I've looked - here, YouTube, etc. - says it can't be done even with the AlfaOBD. But, I have a piece of electrician's tape over the lens now and all I get is a black screen so I guess that's good enough. It's a shame, though, that RAM (and other manufacturers) seem to think everyone wants these nanny features that can't be disabled. The camera thing is a federal mandate that they have to install it, but there is no mandate they we have to use it. It's the same with the horn honking thing when I get out and close the door with the fob in my pocket. It's irritating, I don't want it, but there is no way to disable it.
Don’t know what else to tell you. You have to be smarter than the technology that you’re “forced” to use. In this case, simply defeat the technology with technology, which would be AlfaOBD in this case (and yes, AlfaOBD CAN disable it). It is very simple to use.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Is that an HD thing? There's no horn honk when I get out of the truck with the fob in my pocket on our 2020 1500 Limited.
Marshall
Sk, Canada
2014 sport
I can turn off the horn on my 2014 sport, don’t know about rhe newer ones
I really like the back up cameras
Yrs ago I rigged up one on my big truck for harvest time.
Raadz
