- Jan 17, 2016
- 23,636
- 54,266
- 14 Sport
- 5.7
Here's a picture of the 1500's 8 speed,the vent tube is basically at the very front of the transmission,just behind the convertor,and it's located at roughly the highest point of the transmissions working internals,disregarding where the convertor is located.The smaller tube with the smaller red cap is the vent tube,which has a hose on it a couple feet long,that locates the actual end of the breather tube up into the engine bay.It'd virtually be impossible to fill the transmission to the point it would spit transmission fluid into the engine bay beside the intake manifold.
The other tubes with the red caps are the for the coolant hoses feeding the thermal management unit aka heater,and the back 2 which are a bit smaller then the coolant transfer tubes,feed the lines to the transmission cooler located in the top part of the A/C condensor
