Brake
bassheadhemi
Montreal, Canada
I just want to know if it's normal for our truck to never get a hard brake pedal when you pump the brake (engine on)? Is this because of the ABS?
CTD
Southwest, VA
Yea, I don't know if it is normal but mine does the same. If the truck is off it stiffens up if running the pedal will hit the floor every time. I noticed this when I rerouted my brake lines when I put my headers on.
EDIT: My brakes work great after rerouting and bleeding.
bassheadhemi
bassheadhemi
Montreal, Canada
ok good, i was afraid something was wrong
thx
Sent from my SM-N950W using Tapatalk
Tach_tech
5.7L HEMI
That’s pretty normal of any vehicle with a properly function brake system and the engine running. When the engine is running the booster has a constant vacuum supply. If you pump the pedal with the engine off the pedal will go hard since the vacuum supply in the booster is depleted.
