Cab Vents and Road Noise
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
Just wait until you get 2 people closing the doors at the same time haha
I did the Level 2 seat mod, removed them. You be amazed on how much the rear seats block the road noise. I just
only a year late for the reply
take the suckers out
DreamWeaver
Cleveland, OH
One would think!
Rolling the window down a hair fixes everything. In fact, an annoying part of this is that it's forcing my windows to creep down over the course of 5-10 door slams, because apparently that's the weakest point for pressure to exit.
I replaced the vents with the new design. The old ones looked fine, still. As soon as I put the rear upholstery back in place (couple screws on the coathangers, as I recall), the whistle was back.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
One would think!
Do you have something under the seats that's impeding airflow? The vents "should" be the weakest link (by design).
I might start to have leaks at the rear of the cab.
I shut down my business, due to mostly the raised Commercial Insurance Rates, my Ram was my source of income.
I have had a sign that was mounted horizontally just above the 3rd Brake Light & the space between the Cab & the bed.
I had to remove that sign, because the regular auto insurance agents, mentioned that it indicates a commercial business.
The sign partially blocked rain from hitting the rear of the cab.
I will have to watch for Cab Vent leaks, more so than before
DreamWeaver
Cleveland, OH
I have typical supplies under my seats. I have not noticed that to be an air pathway. But, I will certainly look into it. Is there a duct there I didn't notice? Thanks.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Check this post...
In your case, they may be obstructed...
