CB Radio mounting location
SgtCookeUSMC
Colorado
6.4L HEMI Power Wagon
I know this thread is old but, for those mounting antennae to your bed/stake pockets...how are you getting the wire into the cab?
RangerWeaver
Lancaster Pennsylvania
V8 4.7L
I ran the cable thought the pocket and under the bed. Then along the frame rail. The get it into the cab I drilled a hole through the clutch delete plate.
Socalramfan
Huntington Beach
2011 Big Horn
I replaced the radio and moved it up above the dash. I routed all of the wires and coaxial cable through the dash.
I'm now running a Cobra 29 NW LTD Classic with the antenna mounted using a bed stake mount.
Any pics of your set up?
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
My last truck I found an oval shaped rubber grommet under the drivers seat that I was able to put a small cut it and pushed it thru the floor.
Still trying to figure out a way to mount the antenna with over the rail bed cover? Can't use magnet on roof because of the garage. Thinking bumper??
SgtCookeUSMC
Colorado
I've seen them mounted on the hood..which I cannot do because of my ditch lights. I'm going to mount the antenna on my bed rack.
If you have no flat metal surface to mount your antenna
consider a Zero Ground Plane Antenna
If you have a CB Shop in your area, you might want to drop by & have a talk. CBers love to talk about their equipment
Dieselhorses
Baton Rouge, LA
345 cid
I found a grommet under rear drivers side seat. Still never got SWR’s right. Can’t find a CB shop to save my life.
Stop by a Truck Stop, many truck stops have building out back with a CB shop
Many times the cashiers know where the closest CB shops are
Every Truck Stops sell CBs
Socalramfan or anyone else up fairly close to Ontario California​
If you need your CB tuned, you can't do better than http://www.superiorcb.com/
I have had 3 truckers CBs fixed & or tuned by them
The Ranger CB that i use just was not getting out the way it should have
The radio was set up right & the cable was just the right length, i thought the SWR was just right.
The tuned the Ranger up & i reinstalled it, the outside installer came up & double checked everything,
Then he cut 2 1/2" off of the Big Wilson antenna, then he checked it again & cut off another 3/4"
He said that the SWR was as close to perfect as it could be
Dieselhorses
Baton Rouge, LA
345 cid
When gas prices go down, I'll drive to CA!
Socalramfan
Huntington Beach
2011 Big Horn
Great info :waytogo:
Thanks for sharing with us :waytogo::waytogo:
RangerWeaver
V8 4.7L
So, I have run into a bit of an issue. Since I purchased my ram just over a year ago I had my cb antenna mounted using a bed rail stake mount, but now I have a topper. The topper has a lip that keeps water from getting under the cap and past the rail. Are there any options to mount the antenna using a mount that will allow me to keep it near where I had it?
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
I don't use FM and have removed the antenna. Anyone find a way to use that mount and a firestik antenna ?
odinjunior
Az
For those scratching their heads about garaging with a CB antenna. K40 makes one with a bayonet mount. I have one that I have been using for about 25 years. The magnet is strong enough that I was able to cut a circle out of a thin towel to protect the paint from the magnet.,
