Check Engine Code - Only at High RPMs
ZJGMoparman
North Carolina
I'm a little stumped on an issue with my 2013 Ram with a 5.7 Hemi. The check engine light started flashing a few days ago when I got on the gas hard. My scanner showed a P0303 - Misfire Cyl 3. Of course my first thought was cool and plugs. I swapped coil and plugs out today. After a test drive, it is doing the same thing.
Using my OBD diagnostic, i was able to get some interesting data:
The PWM for Injector 3 seems to be fine with normal driving. When i accelerate hard, the value dropped to 0 and stayed there for a little bit. During this time, i can feel the truck running a little rough. Eventually the PMW went back to normal.
Again, this issue only happens if i accelerate hard for a few seconds. I'm thinking it is a fuel related issue. Does this make sense? Any ideas of what I could check to narrow down the problem?
Burla
2010 Hemi Reg Cab 4x4
Cam Lob, this is how the usually go out. Under load shows up first, I'd take it easy and use a thick oil if you are trying to make it last. You can take over cover and see how the valve is traveling on 3 compared to the others. No tick? Maybe it is injector, dunno man the usual suspect is cam lob.
Brandon-w
Yukon
2015 Ram 1500
Like burla said likely a cam lobe. Pull your valve cover off and take a look, do an oil change and cut the oil filter apart look for shiny bits. Go easy on it and save your money for a new cam, engine or truck. Hopefully it's fuel but sorta doubt it because if the injector was going bad you'd think it'd do it consistently.
Z
ZJGMoparman
North Carolina
That's unfortunate news. I guess my next step is pulling the valve cover to inspect. I just did an oil change last week.
I honestly have not had the HEMI tick in a couple years. I switched to Pennzoil Ultra Platinum a few years ago and the noise seemed to dissapear.
Z
ZJGMoparman
North Carolina
I did pull my oil analysis results from a test i did back in the summer. Nothing seemed to stand out on there of abnormal wear.
  • report.pdf
