Brake_L8
Trying to figure this out as I've learned the Mopar CPO warranty is for drivetrain only and this ancillary stuff isn't necessarily covered.
2016 Ram 1500 5.7L with 47k miles. I don't drive it much and it's parked in an underground garage most of the time.
About 1500 miles ago, I got a CEL and a "Check Gas Cap" message after fueling up. I, of course, checked the gas cap and ran a few tanks through it to see if that would clear it up. Nothing changed.
I then bought a Mopar replacement gas cap, thinking the seal had gone bad. It took a few drive cycles, but the CEL and Check Cap message did go away. A few drive cycles later, it came back and is still on.
I ran the codes and initially had the following:
Stored DTC:
Pending DTC:
Permanent DTC:
I shut the truck off, turned it to Run, and cleared the codes. Everything went away except "Permanent DTC: P0456."
I understand all of these are related to Evap leaks, except P0463, which is something about fuel level. I have not had any issues with the fuel gauge in the cluster. The truck runs fine/normal.
Where do I start with this? I'm happy to DIY it and have seen indications that the purge value could be the culprit. I can poke my head around under the bed and check connections/hoses leading to the evap canister as well. But, didn't know if there was something else to look for.
Stored DTC:
- P0457
- P0456
- P0463
Pending DTC:
- P0455
- P0456
Permanent DTC:
- P0456
