Coolant Gremlins
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
OK it came off easy. Since I didn't have to **** around with a fan clutch (yay eFan!), getting to everything was pretty easy. 13mm ratchet and an extension, as well as a 15, 18 and 19 (one-off bolts).
After the drain, the serpentine belt came off with a turn on the tensioner pulley.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
closed the petcock on the radiator, moved the drip
pan over to the heater hoses and lower radiator for removal.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
3FbozdDtSxSMrDeOTgyDwA.jpg NtdzWrl%TBqOal5CMguJKw.jpg rvhxtG0ZRzS61JmcCs3DVg.jpg
removed temperature sensor and bracket (attached nut to the bracket so I don't lose that l'il *******)
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Moved the thermostat and temperature sensor over to the new pump, installed new gasket.
6H4iy887TceDhKSVtBv1Cg.jpg 6ybYPdFDSeumYUi20iaEgg.jpg cxX933%bQciBzafsKHHASg.jpg UxNbM7EtR%Kmiem2+QPMzg.jpg ZBz%1fKbT+2d34df%uryaQ.jpg
Pull Ya
Cedar Creek, Tx
You can check it out if you wanna drive a little and we can meet for a diet beer somewhere. LOL
Jay
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
OK, reassembled, torque'd to 18 ft/lbs. added 50/50 again. Turned on the heater. The fan kicked on at 180, I never saw the T-stat kick in with the fluid dropping (t-stat may be defective or -- and I doubt it -- I put in in backwards. The truck climbed to 237 before I threw in the towel.
Now I have to wait, drain the coolant again. I am going to pull the T-stat completely, leaving the grommet in there and see if the temp normalizes.
I am honestly beside myself. It may not have been the w-pump after all.
Hemi395
Cape Cod MA
Well that blows........
When I flushed my coolant without the tstat installed it wouldn't go above 150*. Granted it was February in New England but still with all that coolant going continuously through the block yours shouldn't be much higher than that even in the summer in Texas.
How did everything look inside? Clean? Corroded?
EDIT: Did you pull the bleeder plug out when you filled the system with coolant? Could it be airbound?
McBroom
Denison Tx
Hemi 6.4L
SoCal I wish I had been down there to help ya diagnose and fix your truck.
Look at the bottom of your old pump there should be a hole in the casting. If water was leaking from there then pump is bad.
I Love my 18 Ram 2500 4x4 CC U.S.M.C.(ret) CPL
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Nah, oil pressure good, no leaks. Thanks man. This is really freaking me out.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Possibly. I will let it cool, then pull the bleeder plug and go with it until water flows out, then reinsert. Craziness.
SYKRAMMAN
Banned
Jersey shore
06 Mega
That sux man, all that work n nothing. Maybe a partially blocked rad/cooling system, idk.. got me stumped.
