Cylinder Misfire Led to Full Cam/MDS Delete Build + Suspension & Audio Overhaul
4d6n2
4d6n2
North Texas
Oh! I found the rest of the chewed up cam lobe and lifter at the bottom of the oil pan!
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
I do see the two ground cable bolts that had the cable linking the two heads.
Anytime it's a flat braided cable like that, it's usually a system "bonding cable" that usually carries little to no current. Exceptions being, the heavy duty braided flat cable they put between the battery / engine / body. The job of the bonding cable is even more important these days, with the use of aluminum and cast iron / steel together. It helps limit electrolysis when everything is mechanically bonded.
It really doesn't matter where the other end goes, as long as it's a good ground, like the engine or body sheetmetal..
4d6n2
4d6n2
North Texas
Dodginandrammin
MT
Yeah they are very nice! Where may we get them? Or was it custom painted?
Great work on the build, hope it brings you many, many miles of joy!
Jus10case
