Daytime Running Lights
wtabke
Sport 5.2l
Great thread. Gonna have to visit the dealer. But in the mean time, I bought a 2 inch foam paint brush and stuck it between the windshield and the sensor. Leave the headlight on "Auto", and it's not DRL, but lights are always on at startup.
Same basic idea, I found some rubber caps at a local auto parts store and trimmed it a bit.
jcobbdawg
Bloomington, Indiana
Just checking if there has been any recent attempts and successes at the dealership activating this? I have the 2018 Sport with projectors. I actually tried to have the dealership try this going in for recall fix and they couldn't find the sales code but from what I heard, it has to be added then activated correct?
Update: Contacted my service advisor and telling him about the instructions and he said that info is confidential so, word of advice, maybe put a warning on the instructions for us and don't spread the info around too much. Might lose this privilege.
Jimmy07
It never ceases to amaze me the things that the dealer will tell people. If it’s intended to be confidential, he better call FCA and let them know. The instructions can be found by anybody on ram’s website under body builder.
Anyway, everybody just uses AlfaOBD to enable them, now. It also puts the option in the radio settings to turn them on and off.
Gizmoram
San Antonio
2021 Limited
Sorry to hijack...but jimmy I'm sending you messages in a conversation....not sure how to send pm's on this site.....maybe it's cause I'm too new....
Jomikesimpson
Missouri
Do you know how to turn them on with alpha obd because i have been unsuccessful so far
Sent from my SM-G955F using Tapatalk
Have you watched this:
Watch his other videos on how to use AlfaOBD also.
Also the on the first post of the AlfaOBD thread click on: Known Working List
https://www.ramforum.com/threads/alfaobd.123982/
Between the videos and that list I was able to turn on the dedicated DRL outputs but you can select wherever you want.
Keep in mind when testing, that DRLs will not turn on if the truck is in park or the parking brake is set. Do not select DRL drop out if your using the low or high beams, people have had problems with trying that.
Jomikesimpson
Missouri
Still no luck. Im curious if Im missing a component that allows drl
What headlights do you have? and list how your trying to configure them AlfaOBD.
Did you check the radio for the DRL setting and see if that needs to be checked ON?
brianw0048
EcoDiesel
Can I use these and set the turn signals up as DRLs? Would it work?
Jomikesimpson
Missouri
Yes. There is nothing about drl on the radio. They are spyder headlights.
I'm guessing you originally had Quad headlight? Which lights are you trying to turn on as DRLs?
Toddbigboytruck
Ontario
I believe that all dodges can be reconfigured to have day time running lights. Day time running lights are Law Canada. And I have been told by a few mechanics that all they had to do is turn on a switch in the software. When we bring US trucks to Canada
Jomikesimpson
Missouri
Turn signals are what I prefer but at this point i dont care
Jomikesimpson
Missouri
Not real sure how to do that. Do I scree shot it?
Jomikesimpson
Missouri
I will try tomorrow. That picture I uploaded is impossible to read lol
Jomikesimpson
Missouri
SUCCESS! It took me a few tries but i got it with the video and the first post on the thread. Thanks for anyone responsible for the information!
Notes
• Make sure to enable data logging and connect/backup to Google Drive
• 2018 Trucks need security bypass cable
Procedure
Key in RUN position
Open App
Connect to OBD II device
Select DODGE RAM 1500 or 2500 or 3500
Select BODY COMPUTER > MY2013-17 (2018)> CONNECT
Click on the CAR WITH THE OPEN HOOD
Click on PROCEDURE TO START Select PROGRAM CUSTOMER FEATURES
Select PROGRAM CUSTOMER FEATURES Select DAY TIME RUNNING LIGHTS > Select ENABLE > START
Click back on PROGRAM CUSTOMER FEATURES
Select CAR CONFIGURATION CHANGE
Click SELECT OPTION
Select CBC FEATURES-DRL CONFIGURATION
Click SELECT VALUE > Select OPTIONAL DRL > Select OPTIONAL DRL
Click on CBC FEATURES-DRL CONFIGURATION > Click SELECT VALUE
Select CBC FEATURES-DRL LAMP LOCATION
Select LOCATION > Click START
Click on CBC FEATURES-DRL LAMP LOCATION to bring menu back up
Select CBC FEATURES-DRL DROPOUT > Click SELECT VALUE > Select YES > Click START > NEXT
Exit AlphaOBD
Reactions: JB1
Jomikesimpson
Missouri
Notes
Procedure
Key in RUN position
Open App
Click SELECT OPTION
Exit AlphaOBD
2016 Big Horn
