- Joined
- Apr 28, 2012
- Posts
- 27,673
- Reaction score
- 58,033
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
reminds me of the good ol days driving for Rock island, I swear I could smell that video.
They do.Gotta wonder…. With all the clever people who make Tuners… Why hasn’t someone created a tune that gets rid of the “limp” mode?
I agree with everything said here EXCEPT that last sentence. The 68RFE needs some minor electronic tuning to be reliable on a tuned truck.I know nothing about North Dakota, but down in the Southeast area many dealers don't care whether or not a truck is deleted. They're on the lot all the time.
To answer whether or not you should depends on how well you stomach risk. That's a personal question. I will lay out the pros and cons and then you need to decide for yourself.
Pros:
It can be much more economical both in terms of cost and downtime than repairing the emissions system depending upon what failed.
It removes the risk of an emissions failure at an inopportune time.
It significantly improves fuel economy with a proper tune.
Cons:
It is illegal in all 50 states. If your state are sticklers on deletes, you could be faced with some hefty fines and maybe more.
It can cause catastrophic failures of the engine and/or transmission if you get an itchy finger and try to increase power. Stock HP level tune is all that a 68RFE transmission can take and remain reliable.
Ya only lose if you failed to keep the part so that they could be reinstalled before its put up for saleNothing unethical about it. If anything, the unethical part is on the nimrods in gov’t that mandated the need for the truck co’s to design this crap.
If you trade in to a dealer, you lose, so don’t. Just learn how to do a private sale, and then you don’t need to worry about what any dealer thinks or says.
Then delete and enjoy your truck how it was meant to be - guilt free.
I would alter that to say that trans tuning is needed on a tuned truck that has been turned up. If the HP/TQ numbers stay the same, there's no reason to tune the transmission. I always run stock tunes and have never had an issue with the 68. That said... many can't keep their fingers off the buttons and in those cases, it absolutely needs to be tuned. Even then, without some mechanical upgrades it's still not going to be as reliable.I agree with everything said here EXCEPT that last sentence. The 68RFE needs some minor electronic tuning to be reliable on a tuned truck.
The reason it fails if not also tuned is that the transmission ecu is programmed from the factory to shift the truck quickly into higher gears (5 and 6) for fuel mileage concerns and the much higher torque of a tuned 6.7 craps out the converter and clutches bc the converter doesn't get locked. Find a good tuner and you should be gtg.
I've towed all over the country and Canada on 37s with 3.27 geared and tuned 2013 6.7 - 68RFE combo with absolutely ZERO mechanical failure issues. Mostly in the high steep mountians to boot.
To the OP: If you live in a state where you can delete...for reliability you should delete the emmisions systems and keep the parts (for resale). Unless of course you don't like the ethical dilemma part.
Yep... those and valve bodies.... the problem is that folks tune them to increase the line pressure to handle the additional horsepower and torque and firm up the shifts. What they fail to realize is that the 68RFE is built to handle only what it leaves the factory with and even then it kinda cheats to do it. To handle the HP/TQ, it uses fluid coupling where it slowly brings in the power to the trans so as not to shock it and blow it apart. It literally slips between gears. Tuning it takes a lot of that out and introduces more power at once than the transmission was designed for, thus causing it to fail.FWIW, I have a friend in the transmission repair business and he tells me that the most failures he sees on a 68RFE are torque converters, and the only "upgrade" part he typically installs on a 68RFE unless requested otherwise.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 129010 miles.
Agree 100% after a multitude of amazing diesel problems, 4 trips to the dealer, rentals, weeks out of service.Sell it and get a hemi 6.4 problem is solved. It is sick what they put on the cummins, EGR cooler, CATS, DEF, DPF and a turbo that forces air through it all. No Turbo, EGR cooler, DEF or DPF sign me up. We may be running out of time, future gas 2500's are gonna suck even worse until something gives.
Private sales are easy when you live where there are lots of potential buyers. I live in a small farming town with 2000 people. Very small market. I’ve sold lots of vehicles and often struggle with that. Most people from the larger population towns don’t want to drive the 20 to 60 miles to come look at my vehicle. Most of them want to either meet halfway or have me bring it to them. Then I need to take two vehicles and drag someone along with me. And if they end up not buying we’re driving both vehicles back. It’s just not worth the hassle to be honest. Now I just trade them in. My situation will soon change once I move to Florida though lol.Nothing unethical about it. If anything, the unethical part is on the nimrods in gov’t that mandated the need for the truck co’s to design this crap.
Agreed on most of what you said. But understand... it's not IF something in the system will fail, but WHEN. The when is heavily dependent upon how you use the truck normally. Always good to know that before ever buying one. I chalk it up as the cost of ownership (unfortunately).The three things that will keep me in a diesel for towing:
Mileage, it is getting much closer to even, but still like the extra mileage afforded by the diesel, even if it is offset by the higher price per gallon.
Power. Just unbelievable sometimes how good and reliable the power is. Hills more or less disappear.
Exhaust brake. Nothing like it on a gasser. The gassers shifting strategy are a huge help and if the truck is same size and relative weight it will pull very nicely. The diesels are better on a long downhill.
Things that will make me sell for a gasser:
5mph limp mode for an emissions anomaly. First time this truck gets towed for this stupidity it may be gone for good.
Convenience. All the parts are easier to get and cheaper. I know there are some exceptions. But simplicity rules when towing.
My initial technical question still is unanswered.
Can you set the mileage countdown by erasing codes? Is that a thing? Still makes me angry whether or not that is true. But that is what is on my work order.
