Bummer, not much makes me as crazy as being surrounded by a perfectly good power grid and yet I can't start my truck. Bat-sheet crazy.
I have not found a source from the possibilities normally found in my house. I've cut the plug of several 12vdc wall transformers and never really had much success. My patience level could definitely improve but 4 to 5 hours and that's about as long as I could still the wiggle. Battery probably recovered as much on its own as my 1A trickler did but maybe if you have a longer time frame.
The power transformer / converter for internet hardware is often 12v, things like router, modem, Ethernet switch/hub etc. That'll go 120vac to 12vdc. Make sure all your connections are landed extremely well, actually as well as can be, considering the task at hand.
Some of those power sources are really small. The bigger the wall plug unit the higher the power capacity usually. I would think 1A or better to be useful, maybe 750mA. Anything smaller and you might just as well find a neighbor who will give you a jump.
The speaker systems for PC's are often 12vdc also. They might provide a little more power.
If you use more than one transformer in parallel that's getting rather dicey, no matter what you try, keep a super close eye on the transformer (s) for high current failure. If you can smell it, unplug it immediately! A little warmth is ok but hot is not.
Good luck, it'll be interesting to see what kind of sources the forum offers up.
'16 RAM 2500 pw with a Badass Greene tune feed'n & Fire'n a 6.4L w 6spd
CAI / ARH LTs / Solo / 5.13 AAM / 35" Mickey MTs / DOR / Alfa / Custom Graphics / 4% VLT Tint
