Door squeak fix
Hanover Fiste
Air Force
NW Florida
2005 SLT, 2018 Sport
I coated mine with heavy grease. So far, so good...
EagleChief
Oklahoma
2014 Big Horn
To go along with the washer issue... I used the O-Rings that were mentioned and they didn't stay on very long. Maybe a couple of weeks before I found one had come off. Now, I'm pretty sure all of them are off, and I just deal with the noise. I thought I'd try the washers, but sounds like they will work themselves off of the post as well. Maybe some of that chain lube will work. I might give that a try.
EagleChief
Oklahoma
2014 Big Horn
I tried the chain lube... worked for a couple of days and I'm back to the normal sounds. :(
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
Okay so I bought these for my 2017 when I had it...
drop one just over the head of the hinge and it sits between the arm and the head...
My squeak stopped for maybe 6 months to a year
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, 3.21 rear, 8-speed
I used the aerosol spray lithium grease I posted up-thread, lasted a year so far.
Only downside I can see is that the grease is bright white and my truck is dark
blue so it really stands out. But it has worked.
EagleChief
Oklahoma
2014 Big Horn
Yea, I tried that stuff as well, as a few others. It was probably the 3rd or 4th product. Like you, I now have white spray on my hinges. :D
Whatever I put on there, it will only last a couple of days, then it's back to the normal squeaks and groans. Oh well. :shrug:
Curmudgeon
York, Pennsylvania
Perhaps your hings(s) are just too worn, or damaged?
My truck saw about 95% highway miles for the first 100,000 miles, and minimal door use during that time. There was a time in my work life that I used my POV to run service calls and the driver's door took a serious beating.
That noise can be really annoying, to me at least. I hope you find something that works.
EagleChief
Oklahoma
2014 Big Horn
Yea, they may be worn out. I'm at 187k miles and the truck gets used a lot. It's an annoyance on occasion, but most of the time, we pretty much just ignore it.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I feel like mine started shortly after buying new but I could be misremembering.
D1DAVE
HALLETTSVILLE TX
HEMI 5.7
I just use WD40. It stops it for awhile. The reason I use it is my property is mostly sand, and some clay. The sand is gritty. Some of the other lubes collect the sand and turns it into sand paper.
Yes I know WD40 is not a great lubricant, but it works.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
In your case, WD-40 is likely cleaning the grit out...
Magfan2
Montana
Is it 6x3 as was suggested by Smokey613?
Open the door about 6" to a foot ,grab it at the bottom and see how much up and down movement it has,that's the easiest way to determine how badly worn your hinges are
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
I have not seen those bread ties in Belize. So, I used the washers.
We throw bread-bag-closures away weekly. PM me your address and I’ll mail you some.
Teflon or nylon washers would probably work just as well.
KenR 955
Greater Knoxville TN
What was the name of that chain lube, seemed like it lasted quite a while
it may have been PJ 1
It may have been taken off the market, it was made of whale spe*m originally
I used PJ1 Black label. It's been 6 months (2 of snow and winter) and the door is still quiet.
