M4-AR
my truck is under 1k mileage, took the panels off to do a speaker swap this weekend and noticed water in the speaker cups/down the inside of the door behind the track. There was some water poodle inside the door, but nothing leaking into the truck itself.
Called the dealership and they want to water test it for a couple days.
Is this a normal leak for the ram?
I’m dropping it off tonight, but if it’s nothing unusual I may skip it and try and reduce the leak myself.
It did look like the seal closest to the front on both DR side doors was looser than the back.
