Drilling into truck bed sides
Idledrummer
Northern New Jersey
HEMI 5.7
Hi Everyone,
I am installing a power inverter on the truck bed rear side, and possibly Other accessories in the future. I am looking For suggestion on what kind of bolts to use. Also contemplating installing a large metal sheet mesh, then use it to attach any accessories.
Thank you,
Ti
haleme
VA
Are you installing the inverter to the bed side, or outside the bed and running wires to the bed? If I understand correctly, you are installing directly in the bed and don't need to drill holes for bolts. Just use 3/4" long #8 or #10 self tapping sheet metal screws to attach everything.
ibike
Navy Badge
Tennessee
NEXTACK Rivet Nut Tool Rivet Nut Kit with a Step Drill Bit & 80 Nutsert Designed for Tight Space, 8" Rivnut Tool with 8 Mandrels Incl. 6-32 & 8-32 in Organized Storage Case NT600 https://a.co/d/f67SKVC
This will give you a professional looking install plus if you decide to remove it you’ll have a threaded nut that still won’t distract from the appearance of your bed.
Idledrummer
Idledrummer
Northern New Jersey
HEMI 5.7
Yes, I am installing inside the bed. I have a solar panel on the cabin roof, and battery on bed as well.
Idledrummer
Idledrummer
Northern New Jersey
HEMI 5.7
Thanks! I like this a lot!
haleme
VA
I'm installing my inverter in a watertight box under the bed and routing the cables to an outdoor 110V outlet in the bed side.
turkeybird56
Central Texas
OK, how big of an inverter are you installing? Is it pure Sine?
Rivet nut option interesting, not so sure about under the bed, but whatever works for the OP.
ibike
Navy Badge
Tennessee
I’ve got some riv nuts from harbor freight and they are aluminum. The Amazon I referenced are steel. I like the steel much better. I’ve used both and the steel although a bit tougher to use are also much stronger.
Dean2
Near Edmonton
One tip, no matter what you use, paint the hole after you drill it, and then put a silicone bead on the RIV nut, self tapping bolt etc. This goes a long ways to stopping rust starting to form in the area where you made the new holes.
Personally, I would cut out a 3/4" Plywood panel and mount it from bed rail to bed using the existing stake bed pockets and the holes in them. No new holes needed and you can install and use locking nuts on the plywood. Also means the whole shebang is easily removed and leaves no unsightly holes in your bed.
Once the Plywood sheet is in place, these make an easy permanent thread nut that can be added from the bedside without removing the plywood sheet. Just screw it in place to the plywood sheet and you have a threaded nut to bolt the accessories to.
Idledrummer
Idledrummer
Northern New Jersey
HEMI 5.7
I like your idea. I have to remove my vinil bed tray/cover to see what holes are available.
indept
South Jersey
That's going to pull over 40 amps, what size wire are you running on the 12v side?
stdyrln
Corona
Just check behind anywhere you drill- some areas are closer to the outer skin than others- mostly wheel well area. Aluminum or steel riv nuts are fine- need a better tool for stainless since they are harder. You can over crimp-crush them also- so do some testing before you install them.
The other issue is nothings flat on the inside- i got a cheap waterproof case and put my dc-dc charger and other items for my house(2nd battery) i added.
Just lay out everything you need- they dont make alot of this stuff for rams (what they do is expensive) but if you search toyota tacomas or something you can see everything people have thought up.
Idledrummer
Idledrummer
Northern New Jersey
HEMI 5.7
For now, I decided to drill only the bed liner plastic, just for the solar controller. The battery is strapped to the cargo hook, and the converter is just tucked behing the battery. I figure I will test the location before making any permanent install.
