Thanks guys. I found the track time reports with the Vararam Air Grabber. I may ultimately go that direction, or S&B or aFe CAI. (I have no interest in an open box.) With or without air intake, I’m also planning to do Borla cat-back exhaust, and maybe a tune.
Aftermarket CAI appears to be controversial, with several people on this forum claiming that any performance gains are just a result of the air filter, since the stock air box is a CAI. This is the reason I asked for data on drop-in air filters.
Best bang for buck and where you feel a big difference is a tune. Dropping 300 to 400 on a CAI for marginal results can go towards a custom tune. My pickup came with a KN CAI, and if I had the factory parts, I'd probably just put factory CAI back on it. The Hemi is held back by sleepy factory tuning. In terms of best measurable results, custom tune is first MOD to start with.
E fan conversion is a good low buck modification, better throttle response as it takes some weight off the crank.
If that's not enough a header combination is another significant upgrade.
Borla sounds great but the back half of the factory exhaust isn't that bad, it's the front half with the manifolds, CATs, and crushed Y pipe on where the restrictions are at. You could just add a Borla muffler in place of the big factory muffler to get the sound upgrade, but like I said the restriction is near the engine, not the back.
