e-fan temp?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
5-10* warmer than your thermostat. If you are running a stock tstat, then I would set it at 205*...if you have a 180* tstat, then set it to about 185-188*.
R
ram15
Mendocino, Ca
ok thanks, and since someone is on my post. im gonna use a 3.8 fan and was wondering what amp controller i should run cause i see mixed opinions on the amp outputs of the 3.8 fan
