Engine Air Filter, Wix vs Mopar oem, factory warranty
Michael Jones
Washington
6.4L
Time to change my engine air filter. Thinking of going with WIX Standard filter 42725 . Will this void my factory warranty by going with wix or should I just buy a mopar oem and replace?
Tankerpilot01
Lawson, MO
Cummins
Not using OEM legally cannot void a warranty unless it is provided free of charge or it can be proven it causes the failure. Magnuson-Moss Act of 1975.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Your truck still under factory warranty?
No not now but I change to that filter long before I was out of the factory warr.
Like was said that cant void the warrenty unless they can prove the none oem filter was the cause of a failure.
Hemi395
Cape Cod MA
Try a Mopar 68190705AA. Its the factory filter for the 6.4Hemi 2500s and the Ecodiesel. It has much deeper pleats than the factory 5.7 Mopar filter so it will flow slightly better/hold more dirt and will fit in the stock 5.7 airbox.
Michael Jones
Michael Jones
Washington
6.4L
Agreed, yeah, pulled the number as you gave off my stock filter and found it on Amazon for $32. Went by oreillys to see the wix. It is definitely shorter on the pleats than the factory oem.
Another question by changing it myself and or changing the oil and oil filter, void factory warranty?
I'm told to just keep receipt and documentation on when it was changed and mileage....
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
K&N panel filter from azone was like 35.00 (I think) no warranty issues
savage_46
Alaska
6.4 swapped
If you're changing the air filter yourself, make sure you get all 4 clips latched back on. Doing your own oil & filter is OK also. Just keep receipts & document when it's done. I heard Chrysler is starting to require proof of maintenance on some of the extended warranties. Both dealers I've worked for won't ask for proof unless something is blatantly & obviously neglect or abuse, or warranty wants further info. Other dealers may operate differently, best to ask them up front.
