Engine oil cooler ?
jag1886
Boise Id Gods country
Demi 5.7 S&B CAI, flowmaster merge collector, Gibson cat back, oil catch can, 87
I pulled my trailer all last summer and the only thing that runs hot is the engine oil, it will push 250 degrees at times.
Has anyone seen a sandwich type thermostatic adapter for these newer hemi's, I'd like to knock the temps down 20-30 degrees.
charonblk07
Calgary, Ab
F1-A forged 349ci
If you look for the remote oil filter thread we've talked about adding coolers into the external cooling lines that would do what you're looking to do. 250 isn't bad for a proper synthetic oil that would handle the temps better than conventional oil and you could also run a thicker oil if you're not already running a W30.
