Factory Engine Specs?
Kotta390
Ok, so this maybe a long shot on some of the things I am asking for but I wanted to see what you guys knew and what we know about our STOCK 09+ Hemi engines. I have compiled a list of questions and lets see if we can answer them? This is purely for informational reasons only. If you can add to the list that will be great and I will update this thread as we answer these engine specs!
2009+ 5.7L "Eagle" Heads
Intake Flow CFM: 331 @ .650"
Exhaust Flow CFM: 186 @ .650"
Intake Runner CC Volume:
Exhaust Runner CC Volume:
Combustion Chamber Volume: 66.3cc
http://www.hotrod.com/how-to/engine/ccrp-1210-inside-the-g3-hemi-cylinder-head/#ixzz3j24y1UXC
Camshaft
Intake lift: .472
Exhaust lift: .460
Intake Duration @ .050: 186
Exhaust Duration @ .050: 208
Exhaust Duration MDS @ .050: 205
LSA: 115
ICL: 103
Valve Train
Spring Pressure Open: 242.0 lbs. +/- 11 lbs. @ 1.283 in.
Spring Pressure Closed: 97.8 lbs +/- 5.0 lbs. @ 1.771 in.
Intake Pushrod Length: 6.600"
Exhaust Pushrod Length: 7.825"
Intake Valve Size: 2.05
Exhaust Valve Size: 1.55
Rocker Ratio: 1.65
MISC
Compression: 10.5:1
Connecting Rod Length: 6.240"
Stock Size TB: 81mm
Cubic Inches: 345
Bore: 3.92
Stroke: 3.58
Hemi_Express2013
Nantucket, Ma
This is from Tech Auth service manual: Hope it helps you.
09 - Engine, 5.7L / Specifications
SPECIFICATIONS
Eagle Engine - 90° V-8 OHV
DESCRIPTION
SPECIFICATION
Metric
Standard
Displacement
5.7 Liters
348 CID
Bore
99.5 mm
3.92 in.
Stroke
90.9 mm
3.58 in.
Compression Ratio
10.5:1
Max. Variation Between Cylinders
25%
Firing Order
1-8-4-3-6-5-7-2
Lubrication
Pressure Feed - Full Flow Filtration
Cooling System
Liquid Cooled
Cylinder Block
Cast Iron
Cylinder Head
Aluminum
Crankshaft
Nodular Iron
Camshaft
Cast Iron
Pistons
Aluminum Alloy
Connecting Rods
Powdered Metal
CYLINDER BLOCK
DESCRIPTION
SPECIFICATION
Metric
Standard
Cylinder Bore Diameter
99.50 mm
3.92 in.
Out of Round (MAX)
0.0076 mm
0.0003 in.
Taper (MAX)
0.0127 mm
0.0005 in.
Lifter Bore Diameter
21.45 - 21.425 mm
0.8444 - 0.8435 in.
PISTONS
DESCRIPTION
SPECIFICATION
Metric
Standard
Clearance
Measured at 38.0 mm ( 1.5 in.) Below Deck
0.031 - 0.058 mm
0.012 - 0.023 in.
Ring Groove Diameter
Top Groove
90.4 - 90.6 mm
3.56 - 3.57 in.
Second Groove
88.4 - 88.7 mm
3.48 - 3.49 in.
Weight
413 grams
14.56 oz
Piston Length
53.3 mm
2.10 in.
Ring Groove Width
No. 1
1.23 - 1.26 mm
0.048 - 0.0496 in
No. 2
1.23 - 1.25 mm
0.048 - 0.0492 in.
No. 3
2.03 - 2.05 mm
0.079 - 0.080 in.
PISTON PINS
DESCRIPTION
SPECIFICATION
Metric
Standard
Clearance In Piston
0.005 - 0.014 mm
0.0001 - 0.0005 in.
Diameter
24.004 - 24.007 mm
0.945 - 0.9451 in.
Length
62.99 - 63.21 mm
2.47 - 2.48 in.
PISTON RINGS
DESCRIPTION
SPECIFICATION
Metric
Standard
Ring Gap
Top Compression Ring
0.40 - 0.55 mm
0.015 - 0.021 in.
Second Compression Ring
0.24 - 0.51 mm
0.009 - 0.020 in.
Oil Control Rails
0.15 - 0.66 mm
0.0059 - 0.0259 in.
Side Clearance
0.04 - 0.09 mm
0.001 - 0.0035 in.
0.04 - .08 mm
0.001 - 0.0031 in.
Oil Control Rails
0.06 - 0.21 mm
0.002 - 0.008 in.
Ring Width
1.17 - 1.19 mm
0.0460 - 0.0468 in.
1.17 - 1.19 mm
0.0460 - 0.0468 in.
Oil Control Rails
0.387 - 0.413 mm
0.015 - 0.016 in.
CONNECTING RODS
DESCRIPTION
SPECIFICATION
Metric
Standard
Piston Pin Bore Diameter
24.014 - 24.024 mm
0.9454 - 0.9458 in.
Side Clearance
0.10 - 0.35 mm
0.003 - 0.0137 in.
CRANKSHAFT
DESCRIPTION
SPECIFICATION
Metric
Standard
Main Bearing Journal Diameter
64.988 - 65.012 mm
2.5585 - 2.5595 in.
Bearing Clearance
0.023 - 0.051 mm
0.0009 - 0.002 in.
Out of Round (MAX)
0.005 mm
0.0002 in.
Taper (MAX)
0.003 mm
0.0001 in.
End Play
0.052 - 0.282 mm
0.002 - 0.011 in.
End Play (MAX)
0.282 mm
0.011 in.
Connecting Rod Journal Diameter
53.992 - 54.008 mm
2.126 in.
Bearing Clearance
0.020 - 0.060 mm
0.0007 - 0.0023 in.
Out of Round (MAX)
0.005 mm
0.0002 in.
Taper (MAX)
0.003 mm
0.0001 in.
CAMSHAFT
DESCRIPTION
SPECIFICATION
Metric
Standard
No. 1
58.2 mm
2.29 in.
No. 2
57.8 mm
2.28 in.
No. 3
57.4 mm
2.26 in.
No. 4
57.0 mm
2.24 in.
No. 5
43.633 mm
1.72 in.
Bearing To Journal Clearance Standard
No. 1
0.040 - 0.080 mm
.0015 - .003 in.
No. 2
0.050 -0.090 mm
0.0019 - .0035 in.
No. 3
0.040 - 0.080 mm
.0015 - .003 in.
No. 4
0.050 - 0.090 mm
0.0019 - .0035 in.
No. 5
0.040 - 0.080 mm
.0015 - .003 in.
Camshaft End Play
.080 - 0.290mm
0.0031 - 0.0114 in.
VALVE TIMING
DESCRIPTION
SPECIFICATION
Intake
Opens (BTDC)
28.2°
Closes (ATDC)
239.8°
Duration
268°
Exhaust
Opens (BTDC)
274.2°
Closes (ATDC)
15.8°
Duration
290°
Valve Overlap
44°
CYLINDER HEAD
DESCRIPTION
SPECIFICATION
Metric
Standard
Valve Seat Angle
44.5° - 45.0°
Valve Seat Runout (MAX)
0.05 mm
0.0019 in.
Valve Seat Width (finish)
Intake
1.18 - 1.62 mm
.0638 in.
Exhaust
1.48 - 1.92 mm
0.0583 - 0.0756 in.
Guide Bore Diameter (Std.)
7.975 - 8.00 mm
0.3134 - 0.315 in.
HYDRAULIC TAPPETS
DESCRIPTION
SPECIFICATION
Metric
Standard
Body Diameter
21.387 - 21.405 mm
0.8420 - 0.8427 in.
Clearance (to bore)
0.020 - 0.063 mm
0.0008 - 0.0025 in.
Dry Lash
3.0 mm (at the valve)
0.1181 in. (at the valve)
VALVES
DESCRIPTION
SPECIFICATION
Metric
Standard
Face Angle
45.0° - 45.5°
Head Diameter
Intake
51.94 - 52.20 mm
2.04 - 2.06 in.
Exhaust
39.27 - 39.53 mm
1.55 - 1.56 in.
Length (overall)
Intake
130.87 - 131.51 mm
5.152 - 5.178 in.
Exhaust
130.101 - 130.741 mm
5.122 - 5.147 in.
Stem Diameter
Intake
7.935 - 7.953 mm
0.312 - 0.313 in.
Exhaust
7.932 - 7.950 mm
0.312 - 0.313 in.
Stem - to - Guide Clearance
Intake
0.022 - 0.062 mm
0.0009 - 0.0024 in.
Exhaust
0.025 - 0.058 mm
0.0010 - 0.0023 in.
Valve Lift ( @ zero lash)
Intake
12.0 mm
0.472 in.
Exhaust
11.70 mm
0.460 in.
VALVE SPRING
DESCRIPTION
SPECIFICATION
Metric
Standard
Spring Force (valve closed)
435.0 N +/- 22.0 N @ 45 mm
Spring Force (valve open)
1077.0 N +/- 48.0 N @ 32.6 mm.
Free Length (approx).
55.6 mm
2.189 in.
Number of Coils
7.95
Wire Diameter
4.95 × 4.1 mm
0.194 - 0.161 in.
Installed Height (spring seat to bottom of retainer)
46.0 mm
1.81 in.
OIL PUMP
DESCRIPTION
SPECIFICATION
Metric
Standard
Clearance Over Rotors (MAX)
0.095 mm
0.0038 in.
Outer Rotor to Pump Body Clearance (MAX)
.235 mm
0.009 in.
Tip Clearance Between Rotors (MAX)
0.150 mm
0.006 in.
OIL PRESSURE
DESCRIPTION
SPECIFICATION
Metric
Standard
At Curb Idle Speed (MIN)*
25 kPa
4 psi
@ 3000 rpm
170 - 758 kPa
25 - 110 psi
* CAUTION: If pressure is zero at curb idle, DO NOT run engine.
Kotta390
Kotta390
That did help some, but I am a little confused on the intake sizes where it talks about intake valve is 2.04-2.06 and exhaust is 1.55-1.56???? WTF??
Also the camshaft is measured at the manufacturer spot for measuring duration so I need to know what the LSA is still and what the duration of intake and exhaust is at .050?
Otherwise that's a great start!
Kotta390
Kotta390
186 @ .050 intake duration.
205 @ .050 exhaust duration for MDS cylinders.
208 @ .050 exhaust duration for other cylinders.
115 LSA
103 ICL
38 degrees range of motion.
Thank you!
Kotta390
Kotta390
Ok so now The last two pieces that are pretty important are the connecting rod length and the ACTUAL stock TB size, whether it is 09-2012 and 2013+ I am just seeing if they are the same size and if not then what is the size of both?
Also does anyone have any real info on the Eagle heads and flow numbers in stock form?
Kotta390
Kotta390
Corrected the rod lenth above, did if from memory and though about it and was off.
I was just wondering to myself that those are the same 6.125 rod lengths the magnum engines use lol.
Kotta390
Kotta390
Does anyone know the intake and exhaust runner volume in cc?
jcfoshe
Have a question, my son has a 2010 ram 1500 with 5.7 hemi and need to know the connecting rod length. The about confused me a little by what is the actual length, 6.125 or 6.240? Also what is the difference in "eagle" heads and magnum engines?
Knightrider
TN
hey thanks for the info I have a 2015 5.7 would the bearing clearance be the same or did they change?
