Fix a Flat is really only going to work in the tread area anyway, which should be easy to find and fix. Take it off and use the kiddie pool or a spray bottle of soapy water and you should be able to find it. Pay close attention to the bead and stem. if it's in the tread I would just plug it if its the bead or valve stem you're going to have break a bead to clean it (I use a wire brush or scotchbite). They sell TPMS Service kits if its the valve stem. You should be able to find something on Utube that will show you how to do it look at several.
What exactly did the tire shop say? seems strange they can't find a leak that big 10 PSI a day isn't that slow.
