Frame swap
Micchi
Micchi
West Lawn, PA
5.2L
Got my gaskets and various other parts today. Installed the timing chain tensioner and new timing chain from Hughes. Front and rear crank seals installed, oil pan reinstalled.
Working on the freeze plugs. The front 2 had almost no corrosion. 1a003997668d82740b064000b5b159c3.jpgfc91df65415c45d2e577a5c6bf495505.jpg
Sent from my SM-G920P using Tapatalk
Micchi
Micchi
West Lawn, PA
5.2L
Freeze plugs are in, heads are back on. Next step is putting the trans back in.64385662f579630eee86e7fe87c8322e.jpg52b8ef971d160577896376fad6346824.jpgf669374f177710009cf4d98bacfffb09.jpg0d720d05529cd594134c58c89d72b5e0.jpg4d8f7070a582f19261f556ce540302ca.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Trans is in. Going to install the intake, water pump, and exhaust tomorrow.7b37c2b84aee91aebdfd1c9d45f7eac4.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Intake, water pump, and some of the exhaust is on. Can't wait to hear the truck with the new intake!0ce8e6086f381545e7278bcce056b1fa.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Exhaust is welded. Most of the engine wiring is on. Getting close to putting the cab on.7b01e72cff235116f46f9e35ac0e410a.jpga86e83546138e08c2ed57fcb0c662379.jpged2156f8db57e771f9ddda8cbc9aa380.jpg8a51b552cac3aecbb37e740e4e6f8227.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Trans pan now has a drain plug and the upgraded governor solenoid. Added fluids to what I could. No leaks so far. Should be able to get the cab on later this week.7939074709838c6fbbfae4f3efd063b0.jpg7d07913c2fd7b6254a12fd74be4700ae.jpg77b3aea18dae09ee65f4bd89c2c850b4.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Cab is on. Now I just need to connect everything, haha.99123c72d783faa311ba13fc7398dfde.jpgc9cd104af03592ccf49d0adb76241a52.jpgd9073b65ad6a74449f664b4d539d7be1.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Hopefully someone can help. What is this? It had the vacuum line for the climate control going to it. Is it factory or something somebody added?
Micchi
Micchi
West Lawn, PA
5.2L
Got my answer
Micchi
Micchi
West Lawn, PA
5.2L
What did it turn out to be?
-K
From dodge dude94: Those are aftermarket. Supposed to help control the wild vent issue these trucks have, losing vacuum to the mode doors in the HVAC under heavy throttle.
daveray9
Whaaat...
Sent from my SM-G920V using Tapatalk
Micchi
Micchi
West Lawn, PA
5.2L
It was a productive weekend. Got my dash cover, driver's seat cushion, and seat cover from Geno's.
The radiator was falling apart so I decided to replace it. Just need to repair the door bottoms this week.4947da4f33e52a048199d62e8dc9aa75.jpg2a869b75393eb068b6dbd991d9564a42.jpg24a0cd141c16ca64c98a8af1e9046474.jpg6b027bbf3cb45919d6a43934bd0ce4ce.jpg088b713d1f688efc4bde510f1ab3c68f.jpg88e17f60a36785f5a81e4d88547a6f63.jpgbfd108997bc592f0f280b8276bbebf69.jpg485342b1cce657ed0f8519876e65bccd.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Well crap! This is all that's left in the "seats, trim, and carpet" bucket and I have no idea where they go. Especially that ground strap. 69cf23710ae67c3bd13c28784b7c966b.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Extra bolts are the worst!
Yeah. I had different buckets for each section with the hope of eliminating this exact problem.
I am more concerned with where that ground strap goes.
kad
Hudson Valley, NY
5.7L HEMI
If you have access to the service manual, I recall that the SM for my Dakota had a section that showed the location of every ground strap on the vehicle. IIRC, there were 2 or 3 in the engine compartment (block to body), one from the body to the frame and one from the exhaust to the frame.
-K
Micchi
Micchi
West Lawn, PA
5.2L
Doors are patched and back on. Got the fans mounted, just need to run the wires. fe8e8ecbc090e0059bdcba7ba6e57743.jpgdc6543fb1a030afcba858b0a1a83065c.jpg58ad93ccb4d674b0d9401c34fed6e3ad.jpgf76e6272e95022a52f55a294b883a3de.jpg
Orca
