Number1DAW
My truck is in the shop and we will get to that in a moment. I feel like the dealer is being pretty shady. I'm an electrician who works on marine outboards currently and the previous three years worked on marine diesels. I'm not always able to pinpoint an issue but I'm usually able to call BS.
I need to know if the injectors on a 2015 5.7 hemi are open or closed when they have no power. I'm very certain all injectors only open when powered by the pcm but you never know when some engineer decides to throw a NO in the mix.
Here's the issue. I guess during the hurricane last week a squirrel decided to make my engine bay it's home and completely chewed the wires from the harness to two of the injectors on the driver's side bank, as in there are no wires left going to the injector clips. This obviously isn't covered under warranty which sucks, but whatever, I'm fine paying for. They spliced in new injector clips and now they have told me that they believe there is fuel in the oil. (my first thought is did they run a viscosity test or check with a vis gauge? Probably not because they probably don't even know what that is and they don't know what oil I use to have a comparison.) I asked what evidence there was and if the work would be covered under my warranty. The service specialist said that she would have to call tomorrow with the tech to explain the evidence but the work would not be covered because the rodent chewing the wires would have caused the injectors to dump fuel into the cylinders.
My thoughts are:
1) the vehicle was off when the wires were chewed up so there's no way they could have been stuck in the open position for an extended period of time dumping fuel into the cylinder.
2) when I tried starting the truck since there was no connection powering the injector, it would have remained closed and not dumped fuel.
3) even if it did dump fuel, that fuel would have been evacuated on the exhaust stroke and the only way it could have gotten in the oil is if the piston rings failed.
Definitely need to know if I'm just completely wrong about how injectors work, and I'm also thinking I need to get my truck towed to another shop and lawyer up on these people.
My thoughts are:
