Gear swap
Costa16
6cyl 3.7l
I'm upgrading gears in the near future. I'm pretty sure I have 3.55 right now and I was looking on moesperformance and they have a 4.10 and 4.56. I'm planning on running bigger tires and I was told the gear swap would help with the acceleration and maybe the mpg? But I was wondering which would be better.
Thanks.
Statcher1
Kentucky
How big of tires will determine what gears would be best. 4.56s would give you the best performance but would kill MPGs. The 4.10s would be a decent balance of both.
C
Costa16
6cyl 3.7l
I'm thinking 35's maybe 34.5's
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
If you have a 2012, then you will have to either run the factory 4.10 gears or get your carrier machined to accept the aftermarket 4.56 gears. Nobody makes a direct fit 4.56 gear for the 2011-up trucks, so your options are limited. If you decide to have your carrier machined, reach out to Josh at Modern Performance Engineering. He is a member here as well and has done quite a few of these already.
cullen17
Fort Carson, Colorado
Do you happen to know where Josh at Modern Performance Engineering is located? and what is his name on here?
thanks
C
Costa16
6cyl 3.7l
How much would the 4.10's help with acceleration as would it help with mpg's at all?
