- Joined
- Jan 17, 2016
- Posts
- 23,721
- Reaction score
- 54,481
- Ram Year
- 14 Sport
- Engine
- 5.7
What Makes the New Corvette ZR1's Engine So Powerful? An Engineer Explains
We ask an automotive engine calibration engineer how Chevrolet’s new 5.5-liter LT7 V-8 makes more than 1,000 hp.Greg BanishWriterChevroletPhotographerAug 14, 2024
See All 8 Photos
GM recently dropped the details on the new 2025 C8 ZR1. As an engineer who has worked in both OEM development and aftermarket performance, I’m nothing short of impressed. I spent the last quarter-century bouncing between walking the aisles of the Performance Racing Industry show and releasing engine calibrations that have been driven by millions of unsuspecting users around the world. I have seen lots of 1,000-hp engines. I have had lots of engines go to production after passing emissions, durability, NVH, and safety standards. I haven’t seen very many that did both. Sure, there’s the Bugatti ($3 million and 1,200 hp), the Aston Martin Valkyrie ($3 million and 1,000 hp), and the Ferrari SF90 ($540,000 and 986 hp, combined), but all of these are about as available as unicorn tears to mere mortals. Engines like the Hellephant make over 1,000 hp but have zero chance of passing emissions, so they’ll never be offered in legal roadgoing cars. What we have in the ZR1 is a real accomplishment, and a point where my two worlds seem to have collided.
I instantly got a ton of questions from friends on both sides of the industry. Most were along the lines of, “How did they do that?” To me, it’s not the engineering behind it that’s so surprising, but rather the management greenlighting such an impressive engine package. Let’s walk through some of the features to clear things up.
See All 8 Photos
1,064 HP—How Did We Get Here?
The LT6 engine in the C8 Z06 already makes 670 hp in naturally aspirated trim; the LT7 is a derivative of that engine, with boost added. We’ve done this a ton in the aftermarket, with both superchargers and turbos. My own LS3 (ancient technology in comparison) picked up about 200 hp over the base 390 hp when I added 7 psi from a pair of turbos. So, roughly half an atmosphere added 50 percent more power. Apply that math to the LT6, and you can see where I’m going here. Granted, GM reduced the static compression ratio from 12.5:1 down to 9.8:1, so we lose a little efficiency but gain knock resistance and reliability. Rumor has it that the first tests without the wastegates closed (meaning they would have only been running a few psi of boost) yielded about 830 hp without breaking a sweat. Knowing that they somehow got away with running 20 psi makes the 1,064 hp number no surprise at all.We see the same split port (PFI) plus direct injection (DI) scheme used on the LT5 to get all the necessary fuel in there. These systems, made possible by the modern Bosch ECU family, have become common, and make it easy to support big power while still having precise in-cylinder injector control. There’s just enough DI contribution to get the knock suppression benefit needed to run pump gas with good combustion control while the PFI injectors jump in to deliver the required fuel mass at the highest loads. Ford does the same thing on many of the EcoBoost and Coyote engines as well. Having worked on emissions-legal boost with these, I’m definitely a fan of the solution.
Getting the tailpipe emissions that clean requires a fundamentally clean-burning engine that can stay very close to the stoichiometric air-fuel balance, and a catalyst capable of reacting off any leftovers before they exit. Getting that catalyst to work requires that it be warmed up above 300 degrees Celsius very quickly to minimize cold start emissions. This is usually done by creating lots of exhaust gas heat immediately upon startup and directing it toward the catalyst brick.The integral exhaust manifold and turbine housings are the first step here, reducing the amount of metal in contact with the exhaust gases so this heat can be passed along downstream rather than absorbed by the metal. The electronic wastegates can be commanded full-open at startup to provide an easier path to the catalyst rather than going through the turbines. After the turbines, GM used dual-wall construction on the downpipe leading to the catalyst inlet again. The thinner inside pipe again absorbs less heat during the critical startup phase while the thicker outside pipe carries the weight of the assembly.
See All 8 Photos
The selection of 67mm (huge, in OEM terms) turbine wheels is also a benefit here for emissions. Most smaller-displacement turbo engines on the market use relatively small turbines to help spool quickly, preventing lag and delivering low-end torque on demand. The downside to running small turbines is that they often start harnessing the power of the exhaust gases at very low engine speeds, stripping enthalpy (internal energy and pressure) from the gases to perform work on the compressor shaft. A lot of these small-engine programs have trouble keeping their catalysts warm at low speed because of the work being done by the turbos so early. With a healthy 5.5-liter engine, this really isn’t needed anymore, and the larger turbines that allow enough top end flow for 1,064 hp can be used. With over 400 lb-ft on tap before 2,000 rpm, nobody will miss the boost here. The side effect is that the gases going through the turbines aren’t forced to do as much work near idle, so they don’t lose as much heat or energy on their way to the catalyst. This lets the bricks warm up much quicker, like they would on an engine without the turbos, reducing cold start emissions.
Finally, the exceptionally good power-to-weight ratio means that the ZR1 engine doesn’t have to work very hard to meet the docile acceleration requirements of the emissions test traces. Such a favorable ratio means that emissions can remain the priority (rather than power enrichment or component protection) during the majority of driving conditions without the customer noticing.
See All 8 Photos
How Can the Catalysts Live at 1,000-Plus HP?
Read the internet forums and Facebook discussions and you’ll find no shortage of “experts” proclaiming that cats just won’t live with big horsepower. GM already knew how to make cats live at 755 hp on the C7 ZR1, and the new system really isn’t much different. GM still must control the temperature of the bricks (which often requires a significant amount of added fuel), but they get a helping hand from the turbos again. That drop in exhaust enthalpy we talked about earlier comes in on the helpful side here. Gases exiting the turbines are often about 300 degrees cooler after performing work on the turbine blades. This radical drop in temperatures makes life a lot easier on the catalysts at wide-open throttle (WOT). Most of the WOT fueling is there to control inlet temps to the turbine rather than the catalyst. GM’s use of exotic MAR alloy lets them tolerate about 1,040 degrees Celsius of inlet temperature without failing, where most turbo alloys and catalysts are limited to 950 degrees before failing. Dropping that 1,040-degree inlet temp down to around 800 degrees after the turbines goes a long way toward keeping the catalysts from melting. With a supercharged engine, the bricks see whatever gas temp would have been entering the turbines.
See All 8 Photos
