Grinding noise coming from the engine bay when hard accelerating at 5-6k RPM
SugaryClapz
WI
I been trying to figure out what is making a grinding noise in the engine bay when I am at 5-6k rpm. It only happens when I accelerate hard and when it is about to shift to the next gear. I looked on Youtube for videos and forums but it seems nobody has the problem I do. Any help would be appreciated.
ctwalton15
Kansas
a lot of information is missing for an online diagnoses....
Administrator
A video or sound clip might be helpful in diagnosing the problem.
If I had to take a guess it's a change in engine sound when the VVT is changing the valve timing.
SugaryClapz
SugaryClapz
WI
It’s my first Hemi, so maybe that’s just part of it?
ctwalton15
Kansas
I mean it sounds pretty similar to my 09 when I get high into RPM's I don't necessarily hear anything wrong it just sounds like a wide open 5.7l. Maybe i'll see if I can snap a video of mine shortly when I leave work. Yours sounds completely normal to me maybe slightly louder then mine but it could just be simply the phone microphone making it sound louder.
SugaryClapz
SugaryClapz
WI
I think I heard the sound when it was about to shift at the end, but the video cut off..
Administrator
@SugaryClapz is the exhaust stock or has it been replaced? If so what on the truck?
I know @Wild one may have ran a Hemi under hard acceleration once or twice, maybe he'll chime in.
I'm not even sure what he's talking about,as his video's leave alot to be desired.Maybe if he ran it up through a couple gears it'd be easier to hear what he's referring to.
Jeepwalker
WI
2012 Reg Cab, 4x4
As mentioned above, a good, free and easy test would be to look at the motor mounts. At least determine if there seems to be a problem there or not:
1) Open truck hood, Start truck, look at top of engine between hood and lower windshield
2) Hold foot firmly on the brake pedal, put truck into D (keep an eye on engine).
3) Give the accelerator some 'gas' (foot still firm on brake), and see if the engine rocks more than, say, and inch.
4) Then try the same test but this time putting the transmission in Reverse.
5) Keep foot firmly on brake pedal. Don't let the truck lurch or move. Make sure no people are around truck.
If a motor mount is 'bad' or 'failed' an engine will generally lift UP quite a ways.
You also might be hearing nasty harmonics brought on by air rushing through the air tube on it's way to the engine. Are you running a cold air kit or non stock air system?
RamCares
n/a
n/a
We see that you have received some great advice from your fellow forum members! However, if these suggestions do not address your concern and you decide to visit your dealer, our team would be happy to offer additional assistance throughout that process! We're available via private message.
Callie
Ram Cares
Justthebutler
BC
2017 Ram 1500 SLT
Never heard that before, but I do get a nice whistle when I hammer down. Could the noise you hear be the switch from Eco to Giddyup?
indept
South Jersey
Could be a waterpump, alternator, AC compressor pulley or tensioner bearing is going bad. Pop the serpentine belt off and spin everything. Also driveshaft u joints, axle cv joints could be the problem although they typically cause a vibration.
SugaryClapz
SugaryClapz
WI
I am running S&B Dry filter cold air intake, I did the test and the engine does not move.
1SLwLS1
Is the dipstick full?
Orca
