MoparMagic'00
Ok rundown of the rig 2000 1500 with 5.2 auto
Replaced:
Thermostat 195
Radiator
Heater core
Water pump
Rad cap 16 psi
Clutch fan
Issue is that it will not get hot enough to open tstat with clutch fan.. When my clutch fan went out i threw an e fan (no clue on specs but off some 4cly most likely) and obviously could adjust when it kicked on and off.. So tstat was confirmed to open using that method. Now warmer temps are in store ive replaced the clutch fan and again wont heat enough to open stat even with minimal air flow idling in park... Any suggestions? Seems sonething is causing it to over cool..
Replaced:
Thermostat 195
Radiator
Heater core
Water pump
Rad cap 16 psi
Clutch fan
