Homelink
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Well @SitKneelBend - you are the winner - I took out the TCP LED bulb in the opener that I put in about 7 years ago and as soon as I did I barely had to press Homelink and the door was opening, from inside the truck
I did order the Genie bulbs on Amazon should be here tomorrow, as well as the Genie plug-in surge protector (for $13 can't hurt) for the ceiling plug in point
This will end nearly 6 years of frustrating Homelink on my Ram I hope!
Glad it was a simple fix! I just bought these LEDs to keep the bugs from swarming in towards the light and they work too for those interested in brands that may come across your problem...
ricky_bobby
Wake County, NC
6.7L Cummins
Another update - had some spotty issues again, even with new bulbs - I reprogrammed Homelink again last night - do not go by the Homelink site instructions for Ram with the Genie intellicode 2 openers - use the PDF which is similar to the instructions, however, change the battery on the remote fob first to a fresh one, and be sure to place the opener into 'programming' mode for the button you are using to train your Homelink -
Leaving to drop my son off today at pre-K and coming home worked flawless once I reprogrammed according to the instructions - this is a step noted on the Homelink site but not in the main Ram training video
