Hood Latch Assy for the Remote Start Kit wiring question ...
KevinInVT
Graniteville
V6
So I am trying to get oem remote start and I have done all the Alfa programming but I appear to not have anything pinned at #11 on the BCM connector. Is there a way to ground prior to that connection or do I need to pin a wire into #11 and run that to ground?
Ramagain
Wanting to do this mod. I have the wiring from the BCM but no wires out of the second half of the connector. Is there a harness available that I can pin into the back half of the connector that would allow me to add the hood latch?
Ramagain
my body connector had these wires in position 1 and 2 on the body side of the BCM connector, but nothing on the output side. I have pinned the matching wires from a harness I built to the opposite side? Does it make sense that on my 2013 these wires are in a different spot than what's pictured previously in this thread?
Ramagain
Here's my connector and the added harness for the hood switch.
Manduke
Nyc
I have a 2021 ram 5th generation where can I find that connector at I seem not to find it by the battery or underneath the power distribution box anyone knows where is this connector at for my hood ajar wires
Manduke
Nyc
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Reviving this thread to see if I can find an answer on this. I have the plug for the hood switch taped up ready to go from the factory, however, When I look under the TIPM the two wires I think I should see from that plug are not present BUT the two purple wires on the other side going to the BCM are present. So my question is, if I have the hood latch connector already present in the vehicle harness, where are the wires it's connected to currently going? Are the just terminated somewhere in the harness and I'll need to overlay to use it or can I connect to wires already present in the harness?
Below is an "X" for the wires I do have and an "O" for those I don't...
Help me @Jimmy07 ,you're my only hope...
Charlieboy1
