Hi its me again. I have everything I need now. My son and I found the connector under the Fuse box but before I do something wrong, do understand correctly that I am to remove the Number 5 wire from the connector and ground that wire through a 1K ohm resistor? What happens to the wire on the other side of the connector that it connects to? Also where do I find the settings that have to be changed? Sorry about all my confusion.
From your pics, we can now see that your truck is fully wired from the BCM all the way to the two wire connector that plugs into the hood latch with the hood ajar sensor (68159725AB). If you wanted it to operate just like factory, that’s all you would need to buy. If you don’t want to buy the latch, and just want to use the resistor, you can do that too. Put your fuse box back together and start looking for the 2 wire connector up by the radiator that would plug into the latch. I would just take the resistor and jump it between the two terminals, secure it, and put some heat shrink over it, so you always have the option to add the hood latch.
After that, connect the alfa to your BCM by selecting your truck, then body computer, then MY2016-2017 for control unit. Next page click connect, then click the little car with the hood open on the bottom right. Click the select procedure to start drop down menu and scroll all the way to the bottom and select car configuration change. Drop down the select option menu and change these settings:
Remote start present- yes
CBC I/O hood ajar switch input present- yes
CBC I/O usage hood ajar switch usage- 1k parallel resistor
Back out of those screens to where you select your truck. Select Radio frequency hub, then MY2013-2017 PowerNet. Next screen, connect then click car with hood open. Drop down select procedure to start and select RF Hub reset/replace. Enter your PIN and click start. After procedure complete, back out of the app, turn ignition off, remove fob, and exit truck close doors. Let truck sit for a bit, then try remote starting.
