I installed the clamp and the air temps were colder by 7 degrees on average. The driver and passenger left vents were colder and the respective right vents were a few degrees warmer. This likely has something to do with the duct layout, but I’ve not torn into the dash to verify.
I drove a 30 mile circuit and noticed the the coolant temps were 10 degrees hotter than normal. The temps rose from 208-212 to 218-222 at highway speed and near the 230 range at idle. Coincidence, maybe... I pulled the clamp off, ran the same loop and the temps were back to their normal range of 208-212 on the highway and at idle.
From looking at the design of the cooling system, the water pump has a dedicated loop out and back in to the pump supplying coolant to the heater core. The inlet and outlet tubing to the core are the same diameter so theoretically, clamping the outlet will add pressure to the pump, resulting in lower efficiency which resulted in higher temps.
The solution to resolve both the air conditioning temp issue and retain proper engine cooling efficiency is to install a three way valve on both the inlet and outlet lines and an isolation valve between the three way valve and the core on the inlet side.
This is the setup on my tractor which has much higher cooling demands than the Hemi. I’m not going to do this until the warranty drops or it irritates me enough.
