How To Add Heated/Ventelated seats and Heated Wheel to Express/Tradesman
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
All ventilated seats are leather. You can only get ventilated on a Sport with the leather option. The stock Sport seats with the cloth inserts are heated only.
Thanks that was what I meant to say
big john 02
interested in that multiswitch panel posted above, what does the tire light load inflation button do?
big john 02
And deereguy is this the same multiswitch you have?
DeereGuy
Pittsburgh, PA
Mines a little different. I don't have the tire light load inflation button, mine has rear park sense. Everything else is the same.
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
cptwing, clear your inbox please.
69mach1
Cummings 6.7
It was an option on my 2013 Ram 2500 6.7, it allows you to run at 45 PSI on the tires (and not set of the TPMS warning light) while in the light load setting so you can have a smoother ride :naughty: I was just lucky the truck had it as a factory option ;-)
big john 02
i thought I posted this above but I guess i didn't go through. i was wondering if there was anyone that has the programming tool that could program the settings into my truck. I was looking for someone located in northeastern MD DE PA NJ
Ricks Ram
Ricks Ram
Has anyone tried activating the Memory seat module? I saw it in there but did not try to activate it, was thinking about trying it?
Cptwing did you ever get your memory seats working? I am thinking about trying to a activate mine this weekend. If you did get the memory to work did you need to make any extra CAN connections? Also could you post a picture of your yellow seat plug on your driver's side? Since your truck is a single cab like 00/RT's I'm wondering if you have the full option Sport style wiring harness or the Big Horn Style. The Laramie yellow seat plug has 2 extra CAN wires I'm curious if yours is already pre-wired for that. If you were able to get your memory seats working I'm curious to see if you have those wires in the plug. It will help me figure out how to wire mine if I need to add them before I activate the code for the memory seats. Thanks.
DeereGuy
Pittsburgh, PA
Adding Heated/Ventelated seats and Heated Wheel to Express/Tradesman
Rick I don't know if this is a good enough pic or not, but here is a link to some pics he posted when I asked if he had the wiring in his truck
http://www.ramforum.com/f75/adding_...ress_tradesman-96759/index49.html#post1453233
69mach1
Cummings 6.7
I'll be checking my I315 connector for these rear camera wires and I'm guessing they are not there :-( Just one more missing harness to overcome.
I ran into this with the OEM/Jeepguy style camera harness at the i315 vs (edit: Inline-Body/IP). I think it has to do with trucks that may have the adjustable foot pedals/wiring option. On those trucks, the camera wires moved from the i315 to the Inline-Body IP Connector right above it (looks like the CAN IHS pins 26 & 38 went there?) ...
See post 912+ of the Backup Camera thread
M² Mods - From my non Flammable S7!
cptwing
6.4l Hemi
Yes activated the memory function and am able to set the drivers seat positions 1 & 2 and it shows up in the EVIC. The seat works and goes to the preset memory positions, the mirrors do not auto tilt on reverse (was really hoping for this), not sure if they move when the seat position is changed, I did not mess with them to see if they do. I did not know that the memory also stores a radio station, I will have to look at that. Obviously no pedal or telescopic column functionality, the book says that the memory works with this (page 164) do any Rams even have telescopic steering? I will try and take a better picture of the connector. I am getting my new seats this Thursday, hopefully all will just be a swap and the airbag message will be gone.
But mine probably works because its a Tradesman and has more features in the BCM.:favorites13:
Funny thing now looking at the trim levels on Fiat's website you can now get an Express with an 8.4 radio, was this always the case or was this new for 2016+?
Anyone need a set of front Laramie buckets w/o airbags, momma is going to kill me if I have to store a second set some where. These could be a steal for the right person-see post 552, that is dust on the seat wiped right off they are in excellent condition! Anyone 1500-3500 2009-2011 or 4500, 5500 2009 to present.
Ricks Ram
Ricks Ram
Thanks guys I can't see the plug real well in the pictures. It doesn't seem to have the two extra CAN wires but hard to say for sure. Cptwing did you find the memory seat code in ECU Memory#5? I am probably going to set the code and see what happens.
cptwing
6.4l Hemi
I don't remember off the top of my head, where it was. It was either 3 or 5 I think
Ricks Ram
Ricks Ram
OK thanks. I will poke around and see if I can find it. Did you just have to set the one code to get the memory function?
coolemoff1
Does the modules under drive seat handle memory functions
Or is memory strictly from bcm programming
coolemoff1
Rick does the inverter wiring go away from pass seat under carpet up and behind bezel
The truck I'm pulling from is a big horn
And he's got several laramies and longhorn also
coolemoff1
Cptwing u need anything out any those trucks I posted above if u do text me they are 13-15s
