How To Add Heated/Ventelated seats and Heated Wheel to Express/Tradesman
00R/T
CT
Has anyone tried activating the Memory seat module? I saw it in there but did not try to activate it, was thinking about trying it?
No, but yours will probably work since you have all the wiring. I do too, but my current seats don't have the module.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Hey, what's the benefit of the Jeepguy harness compared to using the OEM kit??? Guess I'm not understanding exactly what it is???
Basically, it just plugs into the existing harness connectors vs the splicing.
See post 14 (& 10) of the Cptwing's OEM Backup Camera thread
Post 403 of the original Jeepguy's thread
and feel free to pm me or ask additional Q's on the M² Mods vendor page so we don't sidetrack this thread to much.
M² Mods - From my non Flammable S7!
Ruiner
Alberta
Cummins
If it works, I'll be pulling the pin on an AE Scantool.
coolemoff1
Adding Heated/Ventelated seats and Heated Wheel to Express/Tradesman
Is the dash switch available just heated seats no heated wheel
00R/T
CT
No. Heated seats and wheel always come together. There's no trucks that just have one or the other.
coolemoff1
Ok just wondering I have heated wheel just need spring to install
And plug up scan code I guess
Got part number on spring
Switch panel for diesel truck
coolemoff1
What about passenger seat are most manual heated or power heated I'm looking for just passenger seat I've got heated driver seat
big john 02
Switch panel I recived, sadly not what I needed. But here is the part number and options that came with it for you diesel guys
Sent from my SM-N910V using Tapatalk
DeereGuy
Pittsburgh, PA
What options are you missing?
big john 02
Aside from deereguy, is there anyone else on the east coast that can do the programmiming?
coolemoff1
Man someone needs make pictorial instructional of this mod like cptwing did with 8.4 mod etc
Would sure simplify all info scattered out here and there
69mach1
Cummings 6.7
Here's the correct part number for my truck, I told Benny the options I needed to have on this switch and he gave me the number to order :happy107:
I'm working on the harness install this weekend and hope to at least have heated seats to start with.
Becker11
Illinois
Seat Hardware
I haven't read every page of this thread, but I did scan through quite a bit before posting the question... Which seats have heated and ventilated hardware? My truck has heated cloth seats from factory. Is there a chance that they are the same as heated/ventilated without required switch gear? OR Would I have to go buy replacement seats in addition to the wiring/switches/codes?
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
Heated cooled seats are an option on Sport models, Standard on Laramie and up. Both in leather or leather with cloth insert. I do not believe the ventilation option is available in any of the cloth only trims. Sounds like you have a bighorn with heated wheel and seats. If you wanted to upgrade to factory ventilated seats you would need to buy optioned out sport seats or seats from a Laramie and up. I would guess you have all the wiring you need and would just need the sales code.
In short no you current seats are not set up and do not contain the components for cooling.
00R/T
CT
All ventilated seats are leather. You can only get ventilated on a Sport with the leather option. The stock Sport seats with the cloth inserts are heated only.
Pocho808
