Let us know how you like the woolwax. I'm curious if it lives up to it's reputation that it stays better than FF.Thanks for the write up. I bought a 5 gallon bucket of the thicker woolwax I'm going to apply. I also have a gallon of a thinner product for the inner panels. https://www.amazon.com/gp/product/B07WJJB6P5/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Fluid Film is coming out with a black colored product in September. I probably won't coat the undercarriage with something that is black because like @U&A pointed out, it's nice to be able to see the metal through the FF. But I think for things like the suspension control arms, rear axle, and anything you can partially see it would make it look nicer[emoji106]
That's good news for your truck, less miles and wear/tear[emoji106]So I just got the call today that my work from home situation may become permanent.
Since I wont really be driving anywhere, I might consider changing to an every-other-year undercoating schedule.
I have noticed in the past few weeks, though, oil spots showing up on my driveway. Freaked out thinking it was the engine, trans, etc. After putting some clean cardboard under the truck overnight, it turns out its the Corrosion Free "creeping" and running down the wheel well lips and falling onto the ground. Also dripping off the frame rails and crossmembers under the truck.
Never experienced it before, the only thing I can think of is since I dont drive it much anymore, it was dripping in someone else's parking lot (work) before I brought it home.
Interesting, how long ago did you apply it? I'm not sure I've heard of any of the oil based undercoatings dripping like that after theyve been applied for a period of time...
Let's not overlook another reason all vehicles rot out quick without attention and that is thickness of metal. There is a reason that a car from the 40's, 50's, 60's and even some early 70's can sit in a bone yard for 40 years and not be rotted into the ground and that is thick a** steel.
I just sprayed my 2018 ram 2500, the underneath was pristine and I want to keep it that way. Took about 2 gallons crew cab long bed to do everything. I did notice that one side on the bed when I removed the wheel well liner that there was foam coming out the bedside holes. I took wire and ran into the foam to get a heavy dose of fluid film in. The other bed side was easy peasy.
Where do you get them plugs that go into the bottom of the rocker panels at?
I also painted the exhaust with high temp black and the driveshaft with enamel.
Now i got to put on my duraflap mudflaps whenever ups decides to bring. On weather delay now for some reason.
Where is the best place to drill door and rocker holes? Anybody know?
What size and where and what to use for plugs?
I agree, FCA put more than enough access holes in the body of these trucks to spray into[emoji106]FWIW I never drilled holes anywhere.
For the rockers, there are 2 "ways in" from the bottom: 1 set is the holes with tape over them, where the running boards would mount. And the other set are tucked under the bottom of the rockers with (many) small rubber plugs. I pull out every other or every third plug, insert the sprayer hose, pull the trigger and "spin" the hose to get both sides of the hole I opened. The taped holes I pull back the tape and do the same thing, but in every hole since there arent many.
Doors - AFAIK the only real issue in the doors is at the bottom where the skin comes together with the frame. Easiest way to get that is to take off the lower "skirt" weatherstrip, then shoot undercoating through each of the drain holes....it will warm up and "creep" down into the crevice that usually rusts.
There are also plugs about halfway up the A and B pillar (from the factory)...I pull those plugs and spray while spinning the nozzle.
