How To: Fogs on with the High Beams
MitchPeder7
Clyde Alberta canada
Just did this to my truck tonight! Works great so far. I did the mrtaillight kit in my last truck but it was a waste of money for how simple this really is. Parts cost me less then $25 including heat shrink and tape.
Sent while I'm killing time at work
Stlram81
Can get the kit on Ebay (highbeamkits.net) for $20.
Sent from my SM-G900V using Tapatalk
R.L.K.
Bristol , Tn.
For a High beam with fogs on for a 2013 + Ram , go to www.harness-connection.us
CuylerTech is a member here and operating the harness connection he does custom harnesses with or without relays for highs & Fogs .
Also does other harnesses .
He will also make a spacific special order harness ...
Hope this helps !
Little Red
NY, USA
Is the harness-connection.us harness a plug and play, setup?
R.L.K.
Bristol , Tn.
Absolutely PLUG - N - PLAY my friend , a fantastic set up imo !
Hope this helps ...
R.L.K.
Bristol , Tn.
Sweet. Thanks for input. I'll be adding this to my mods list.
You will love this kit ! PM me if U have any Qs ....
Two identical harnesses one for each side , no relay , no wire splices or taps needed , just plug it to the headlight and the fogs and there you have it ! OEM type harness .
Remember this is for 2013+ vehicles.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
This has come up in discussions before. Dealers won't do it as it's some kind of safety violation (at least that's what I've been told) and no programmer can do it as of now.
Most states it is illegal to run them that way. I never could figure out their reasoning why?
drooler
Alberta, Canada
2015 Sport
Attn: Cuylertech. I've sent a couple of e-mails now to harness connection with the only reply received 2 months ago stating that you had to locate a 2015 in order to test.
Just wondering if you found one and if your kit will work on the 2015+?
Thanks.
Venusj
V6
Is there a way to add led bad behind the grill without removing the active grills. I would have them come on with my high beams as well
WilliamS
Tampa FL
Has to be a better way! On my old car (focus) you removed the relay and replaced it with a single wire between 2 of the terminals. This allowed the fog lamps in any position of the headlights and high beams. Basically it removed the cars override of that relay to shut them off when the high beams were turned on.
But for 25 bucks a plug and play harness is a really good option. But the website is down?
R.L.K.
Bristol , Tn.
Yep , I believe the harness connection went out of business earlier this year ?
To bad he was at one time a great asset to the forum.
Rumor has it he went to ferd
Mr.AK902
Regina,SK
17'
There is. On all 4th gens, turn your frog lights on with your low beams, snap the light controls on left hand side of wheel back towards yourself then all the way forward to the high beam position. Movement has to be fast and smooth and voila you've got los his and fogs at once. Headlight selector must be manually on and not in the auto position. Works like a charm.
WilliamS
Tampa FL
Programmed with the AutoEnginuity tool, no tricks just turn on high beams and fogs stay on
Ricks Ram
I did the same thing. Just turned them on with the AE tool.
Sent from my SCH-I545 using Tapatalk
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
Link to such a device? And does it work with 2018’s?
Fryekenn
