sac2dude
Orangevale, CA
no. It loads the earth screen. Then it pops up a map with the little truck icon. On a street that I believe is in Colorado (I’m in New Mexico). Lol. And it just says “looking for satellites”. I reset it. Phone pairs fine and stays paired. Pulled all plugs. Including opening up the unit and made sure everything in there was connected. I even re-connected my old unit and the gps comes right up. Oh well. I’ll see what happens in the next couple days.
Interesting. I haven't had that issue. Either it gets stuck "loading" or it works great with a spot-on location. That seems like an antenna hookup issue. I was surprised to learn that in CarPlay, the iPhone utilizes the RAM GPS antenna. I had no idea that was the case, but I tested it and indeed the iPhone is using the GPS signal provided by UConnect. If the factory Nav displays my truck off on a parallel road, and I switch to CarPlay, then Google Maps will show me the exact same thing..
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Yep. Looks like it’s stuck in that location. I am pulling the battery now in hopes it fixes it. If not. Maybe I can change the gps card?
I forgot you opened it to replace the screen. Are you sure you reconnected the antenna internally and on the right connection?
bohrman44
Alamogordo, NM
3.0 Eco Diesel
I’ll open it up and check. I did disconnect the small connectors in there. But I did reconnect them. There’s only 1 spot they can go. After looking at Powerwagons diagram. The violet (H) connector is open on my deck after I connected everything. I’m gonna try moving the purple cable over and see if that works
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Conversely, you could buy a cheap GPS antenna like this to test on the radio.
https://www.amazon.com/dp/B07R6NMB45/ref=cm_sw_r_cp_apa_i_PYTjFb8P8CBMQ
48PowerWagon
Bellingham, WA
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
I don't really have any issues with my UAQ, but I do have a question. Sometimes when I start the truck after only being out of it for 15 minutes or so the time is off by 5 hours exactly. It corrects itself within 15 seconds but I was just curious why it happens.
bohrman44
Alamogordo, NM
3.0 Eco Diesel
Ordered it. Can’t hurt. I opened it up and made sure all the connections were good. All good. There’s a little card on the side of the unit that has all the wires going to the plugs on the unit. So maybe that card is bad. Says “Sierra” on it. Anyone know where I can maybe get one of these boards? The number on it came up with nothing in google
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Another radio is all I can think of...someone lurking here may have one.
cblood95
Austin
Hemi - 5.7
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
If you want to keep the screen protected underneath I've been recommending this protector...
https://www.amazon.com/dp/B01DVSYTTK/ref=cm_sw_r_cp_apa_i_uCxkFbCX29Z09
It ships from Germany and is more easily applied with the HVAC bezel not installed or the radio completely removed from the truck.
@SitKneelBend how prone is this one to showing fingerprints? I have one now and I don't know what brand it is but it shows everything.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I've only had it in for a few days but it doesn't appear (so far) to get very printed at all. I'll take some pictures later today and post them. I'll also open the sunroof for a real good test.
I will say I haven't seen a matte screen protector quite like this. It is fairly thick and resilient but not blurry or cloudy when installed.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Seems to do well with fingerprints. Barely noticeable until I swiped behind my ear to really oil it up. It actually wiped away pretty easily with my other finger? Any glare you see in these photos is entirely positional and generally not noticeable from the driver's seat. It also is exaggerated by the camera and not as "glaring" in person.
Fingered...
Oily fingered ...
Wiped by finger...
Driver view screen on sunroof open...
Express Man
Is there such thing as a 2019 8.4 ra2? It's the large screen but the back of the radio says ra2?
Sent from my SM-G986U1 using Tapatalk
Sdpadrez
Looking to see if anyone has a solution for putting in a compass hub in a 2015 Dodge Ram Jump Seat. My original media hub was wider and with this new compass hub I have a gap in the tray.
Express Man
Could fill it in with something or buy the insert where that hub is made for. Here is the part #68376066AA
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
A word of caution for those looking for a ram compatible 4th Gen 2018/19 classic UAQ or UAS radios...
** Not saying what's good, what's not, or whether it 'Can' work. Just be aware of what you're getting **
>> If you find a radio n and know it came out of a ram truck from a salvage yard, etc (ie with vin) and has has one of the 2 PNs listed in the OP, you are much better off <<
There's an eBay seller (lombeephre) repairing radios and I'm fairly certain he's mixing rear cases with different PN radios/internal hardware and the SW I see loaded doesn't look correct either. (ie application version shows non USA country & version # )
For example:
Rear view of a factory 2018 ram UAS (68331635Ax) and UAQ (68331631Ax) radio ... 7494d84907ec9d4d36f8e955169f79d6.jpg
And here's the 2018 UAS (68331635Ax) that's currently listed. See the difference in the connectors? (It's likely from another 2017 Chrysler brand ...
This UAQ (68331631Ax) hardware looks correct physically but appears to be running a Jeep Sw load (fairly certain, Jeep got a different hardware PN than the RAM) ... See the menu icon differences. (Radio may have just loaded the Jeep theme if bench test SW is saying it's installed in a Jeep)
Here's the factory RAM UAQ SW icons (application version 18.x to 22.6) ...
2018 ram UAQ (68331631Ax) Application version screen...
chri5k
USA
Diesel
Yes that Ebay sellers store is a bit odd. A mix of car parts and computer parts. A number of the radios (like the one above) look like they have been in the weather. This seller looks like someone that buys auction lots of used / recycled electronics culls through them for stuff that looks OK and sells it on Ebay. With all the different brand radios he has it would seem unlikely he has the equipment to actually test them before selling them. Definitely a "buyer beware" scenario. Not the first time we have seen this. Wasn't there a facebook seller that was selling Frankenradio's about a year ago? I seem to remember a rash of those coming through the threads with forum members who bought them for an upgrade and had problems.
18harvest
huntsville
I believe he has came across a supply of test/demo radios.he has a lot of 21 for sale.most of them have a factory use only sticker and aa on the part number which is usually the start of a production run then goes to ab then ac and etc.more than likely these were to be disabled and or disposed of.which would explain some not having software.i have Franesteined a radio but tested it and was upfront and priced accordingly.
Cesar592
3.6 pentastar
[QUOTE = "Mpgrimm2, publicación: 2332420, miembro: 21548"] Una advertencia para aquellos que buscan radios UAQ o UAS clásicas 2018/19 compatibles con ram ...
** Sin decir qué es bueno, qué no o si 'Puede' funcionar. Solo ten en cuenta lo que obtienes **
Hay un vendedor de eBay (lombeephre) reparando radios y estoy bastante seguro de que está mezclando carcasas traseras con diferentes radios PN y el SW que veo cargado tampoco parece correcto.
Por ejemplo:
Vista posterior de una radio de fábrica 2018 ram UAS (68331635Ax) y UAQ (68331631Ax) ... 7494d84907ec9d4d36f8e955169f79d6.jpg
Y aquí está el UAS 2018 (68331635Ax) que se encuentra actualmente en la lista. ¿Ves la diferencia en los conectores? (Es probable que sea de otra marca Chrysler 2017 ...
Este hardware UAQ (68331631Ax) parece correcto físicamente, pero parece estar ejecutando una carga Jeep Sw (es bastante seguro, Jeep tiene un PN de hardware diferente a la RAM) ... Vea las diferencias del icono del menú
Aquí están los iconos de RAM UAQ SW de fábrica (versión de la aplicación 18.xa 22.6) ...
59d314522847c47ec3ff1a53286014b0.jpg[/CITAR]
Jus10case
