SKB, thanks for the tip on the LOCA. My screen is still working fine with no ghost touches. It just has the delamination pattern. I'll give the LOCA a shot and report back.
Definitely do, here is my deeper discussion on this topic. Take a look before trying, maybe you can improve on my method...read from this post on for my findings.SKB, thanks for the tip on the LOCA. My screen is still working fine with no ghost touches. It just has the delamination pattern. I'll give the LOCA a shot and report back.
After pulling the bottom of the armrest apart and looking at the wiring from the hub down to the top of the bottom part of the jump seat I didn't notice any issues and left the camera up while I was moving wiring around to see if anything changed but no luck. Is there another spot under the bottom portion underneath the bottom of the jump seat base I may be missing? I'm not techy enough to add my own rca outs unfortunately lol.If you have the jumpseat like me, I just disconnected the hub harness under the seat to verify that this corrected the restart behavior. I ended up just leaving the factory AUX pins disconnected at the back of the radio harness and added my own RCA outs on those pins (so the short is disconnected). Inspecting the harness and repairing the short should work just as well.
The harness connects under the driver's seat in the front right corner (as you are sitting in it). Disconnect there and see if the reboots occur while driving.After pulling the bottom of the armrest apart and looking at the wiring from the hub down to the top of the bottom part of the jump seat I didn't notice any issues and left the camera up while I was moving wiring around to see if anything changed but no luck. Is there another spot under the bottom portion underneath the bottom of the jump seat base I may be missing? I'm not techy enough to add my own rca outs unfortunately lol.
'16 CCSB 4X4 G56 2500 6.7 SLT, CTT tuning, UAQ, Single Zone ATC
Buy it from here:Greetings all. How can I purchase the media hub harness? I currently have the 8.4 with nav, upgrading to UAQ. Have the hub 68328704AC, but I take it I need a harness to make it work correctly
If your truck is a 2018, the hub in the storage under the armrest will allow you to plug in your phone and use car play or Android auto. I have 2018 2500, came with basic radio, media port worked just fine. On harness, I have no idea. Maybe you should reach out and ask if you can change it. Good luck.Hi guys, i am about to proced to the 8.4 UAS radio conversion. Right now i have a ra2 (i beleive, the 5 inch one).
I have 2 questions that i have found some informations, but not enough to confirm if it will work or not. The first one is critical,
I did order the conversion harness for the HVAC, but like an idiot i mentionned 7 speed motor instead of 4 speed motor. I do have a 4 speed motor, I can guess it is not okay, but will it still work with bugs, or not at all ?
My second question is about the media hub, i have a Ram 2018, and everywhere i see talks about 2013 to 2017, but nothing about the 2018 besides it is not the same hub, but will it works with apple carplay, or i still have to change it ?
Thanks all for your time!
What's interesting is that brand new 4th gen Ram UAQ and UAS radios are shipping with the JR 34.2 sw and also have the device not recognized issue.I did some more testing recently with several of the firmwares available for Jeeps that work for Rams. My "test" 2018 UAQ was suffering from the loud notifications after that constantly reset to 15.
I tried to wait for the update for v22.61 but was never prompted. I'm curious if anyone who was already running v22.6 was prompted for the v22.61 firmware?
Anyway, I successfully flashed 3 different Jeep firmwares (28.3, 30.24 ,34.2). All worked well but all gave the "device not recognized" error upon plugging in a cell phone to the USB hub. I suspect this is a driver issue but would need a Jeep USB hub to confirm. It's a far less bothersome error than the loud notifications.
That being said, the loud notifications was only solved by the latest Jeep UAQ firmware v34.2. In the two prior versions, the notifications remained loud.
In addition, if you flash v30.24 you should remove the Jeep map updates included. I believe it can cause the Navigation to become unresponsive and fail to load. @18harvest ran into this issue I believe.
Note that going to this firmware is irreversible until RAM provides firmware with a version number higher than v28.3 but one can go back to at least Jeep firmware v28.3 from either 30.24 or 34.2 (for some reason, the downgrade works for Jeep specific firmware). I'd also be curious to see if even older Jeep firmware would downgrade to anything prior to 22.6, then upgrade to v21.9 RAM firmware and see if the OTA to v22.61 comes through (and fixes loud notifications). Just a thought...
What exact panasonic radio PN/model are you using?2017 Laramie longhorn can confirm the Chrysler 200 hub works flawlessly. Used a fruit peeling knife to shave some plastic. Looks nice and neat no gaps! Thank you Mpgrimm2 for the harness and advice.
That is interesting, and now I don't feel bad for going past the point of no return!What's interesting is that brand new 4th gen Ram UAQ and UAS radios are shipping with the JR 34.2 sw and also have the device not recognized issue.
@Earl Zeis has run into this recently even with the 2018 ram USB Hub xxxxxx704Ax. Not sure if the 2018 Jeep compass hub or 200 Chrysler Hub would have this issue.
M² Mods.
(via Tapatalk App)
see his post 3071 here.That is interesting, and now I don't feel bad for going past the point of no return!
Yeah, I saw that one. Mine has the same message, but instead of at startup mine only displays the message when I plug in my phone.
So, I came across the 5th Gen Ram Forum post on the device not supported error and tried this fix (which kinda worked)...What's interesting is that brand new 4th gen Ram UAQ and UAS radios are shipping with the JR 34.2 sw and also have the device not recognized issue.
@Earl Zeis has run into this recently even with the 2018 ram USB Hub xxxxxx704Ax. Not sure if the 2018 Jeep compass hub or 200 Chrysler Hub would have this issue. see his post 3071 here.
M² Mods.
(via Tapatalk App)
