nrenne98
Minnesota
We have a few 22 classics with 8.4 uconnect 5's. I was curious so I checked out the radio on StarParts and it lists at $700. Everything appears to be the same as the 18-21 Classics. I may buy one using my discount at work and try it in my 2017 Ram. Has anyone tried a Uconnect 5 8.4 in the 4th gen? If so what was needed?
mtnrider
Georgia
Might want to consult with @Jimmy07 but I'm pretty sure it won't work from what I remember reading, at least not all functions anyway?
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
And I believe the radio connectors are different as well.
nrenne98
Minnesota
Bummer I thought I would be able to get a CarPlay radio into my truck for cheaper than a UAS. I am willing to take the $450 gamble if just some wiring needs to be adapted. I work in a CJDR part department so I have access to some helpful info but I can't see for certain if it'll work as the UAS/UAQ does.
Mpgrimm2
Preferred Vendor
SC
5.7L
Not something I am actively working on vs recommending a Panasonic 4c radio.
Sdpadrez
Hello all. I have a 2015 ram express 1500 with the 8.4 CarPlay radio all working using an aftermarket bezel. I’m wanting to go all OEM now. Has anyone experienced any issues in installing a used 68366552AA HVAC when upgrading to the 8.4 UAS?
JoeGo88
Colorado
EcoDiesel 3.0
I have done the radio upgrade already and it's working great. I recently installed a wireless adapter for ACP. It works good but once I try to plug the phone in so I can charge it it seems to confuse the radio and adapter. Is there a way to make one of the USB ports a charge only and the other connect to ACP? I have alfaOBD and looked at external port type and tried changing to USB + AUX but both USB ports still connected to ACP. Any help would be appreciated. Thanks!
Oldschool71
Indiana
6.4L
Hello and I apologize if this is in this posting already but want to know if a 68331635AK will work as a replacement radio in my 2016 rebel? I am trying to get android auto feature.
NYMustang50
Long Island, NY
Cummins 6.7
Just curious. When I put the new Radio in my truck it reads from the BCM to see what the truck is equipped with correct?
How do I get it to refresh again at a later time to re-read from the BCM?
Mpgrimm2
Preferred Vendor
SC
5.7L
Yes, that should be a good fit (depending on your exact setup, there can still be some issues that pop up)
Mpgrimm2
Preferred Vendor
SC
5.7L
Correct. It can take 30 mins to 2 days to finish.
Pull the inline radio fuse under the hood by the firewall to force a reset. (Or battery)
Oldschool71
Indiana
6.4L
Can you please explain what you mean by "exact setup" are there some things I should watch for on this swap on my 16 Rebel?
Mpgrimm2
Preferred Vendor
SC
5.7L
Answer these questions....
What Radio you originally had:
(ie RA2 5.0” radio with Phone/VR button & Mics on Mirror handsfree calling? Satellite Radio?? )
** If factory 8.4 radio equipped... Does it have Dual Zone ATC (Auto Temp Climate Control)?
8.4 Radio type:
(What’s the Actual PN , Year/Model of the 2018/Classic 4th Gen UAS/UAQ 8.4 radio you plan to use? ie 2018 UAQ PN: 68331631AK. Stick with 4th Gen Panasonic 4c radios. 5th gen Aptiv/Delphi radios have issues)
Parts:
(Any parts you already have/bought, with actual PNs please? ie HVAC module, 8.4 bezel, etc?)
Other:
(any other specific info, Backup/Cargo Cam? If so, where do they display?)
I'll check back later
Oldschool71
Indiana
6.4L
Answers are below each question. Thanks in advance.
I have all of the functions that you have listed.
I do have the 8.4 radio equipped, I have the ATC as well.
8.4 Radio type:
I am planning on buying the 68331635AK from a 2019 Ram.
Parts:
As I understand it I do not need the bezel as I already have an 8.4 radio and am just upgrading to a newer version. I have purchased the 5XG28DX9AD (Compass Aux)
Other
I do have the backup camera and it is displayed on the current 8.4 screen.
Mpgrimm2
Preferred Vendor
SC
5.7L
What is the part number for the chrysler 200 dual usb?
It's listed in post 5. They have been on backorder for over a year.
You should just need the Panasonic 4c radio, USB hub and Hub adapter harness for your setup. Your radio PN looks good.
Cheap knockoff Compass USB Hubs usually don't work vs genuine Mopar
cvillechopper
Charlottesville, VA
2015 Laramie
Has anyone tried pn 68575675AA? Found one locally for a really good price but more than I want to spend for a paper weight...
Mpgrimm2
Preferred Vendor
SC
5.7L
Pictures of it? Front/back, side showing PN sticker?
cvillechopper
Charlottesville, VA
2015 Laramie
Pics below but I just looked and they posted additional pics. It's not an 8.4. Much smaller screen so no use to me anyway. Thanks anyway. Still trying to find one locally with no luck. Seems there are a few folks that are able to scoop them up and are making a business out of reselling. Good for them, more costly for the rest of us. Such is life.
chri5k
USA
Diesel
And the worst part is when their customers have problems they come here for support. :confused:
