PaleFlyer
Charlotte NC
New member of the Android auto club here and loving it (in my 2017 Ram). Installed a UCQ (68340153AH, Canadian equivalent to UAQ from 2018 Ram). Got it from a salvage yard in Saskatoon for $500 plus shipping Canadian $.
I installed a USB C hub from a 2019 Ram and all works great, minus a couple issues.
First, sxm works fine and Android auto works perfectly (wireless with Moto MA1 adapter btw), totally recommended!
My issues
- Factory navigation just shows "Loading navigation" and it never proceeds to an actual map. While Android auto is nice, I live in Colorado and there are many dead spots in cell coverage.
- My radio presets occasionally disappear after starting up the truck.
Would loading the v39 update fix these issues? I'd assume that the navigation/gps uses the same antenna as the sxm, right? My sxm which works fine.
Any ideas?
You would need the map pack as well. It sounds like the UCQ you have might have a bad map pack. It is something you have to manually inject into the update. I think the "latest" map pack in the firmware thread is from the 22.5 firmware, but I stuck that in the 39.5, and it worked fine. I think I checked that nav loaded after I did the update, but I don't remember, and I don't use it.
On the flip side, you can do "offline maps" on your android, and pre-download the maps for the area you are going to be traveling through, so it is running off the local copy, versus streaming the map the whole trip, and it is more resistant to cell dropouts (if the GPS in your phone doesn't go dumb as well... It happens sometimes...) I generally don't notice I lose cell coverage until the music stops because of this.
SXM, Cellular, and GPS are all in the sharkfin, but they shouldn't be the same physical antenna I don't think (so the sharkfin should have 3 different PCB/Chip/widgets if you crack the top, someone posted an internal pic in a thread about swapping the sharkfin for the puck recently.) But at least 2 of them share a cable (SXM and GPS I think based on the "puck" antenna)
Average J0e
Nebraska
2017 Lone Star SLT 1500 Rambox
5.7L V8 HEMI MDS VVT
Will a Uconnect 8.4 out of a 2019, 2020 or 2021 Ram fit a 2017 Ram that has a Uconnect 8.4 in it already?
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Not counting other setup/feature details that may be different between trucks...
It would need to be a Panasonic 4c out of a 4th gen 19-21 'Classic' truck. ... New body style 5th Gen trucks use a different radio (by Aptiv/Delphi) and have issues.
Average J0e
Nebraska
Thanks! I saw your previous about the Aptiv/Delphi issuses. I have been looking for a Harmon to do the upgrade with. Is there a specific p/n for the Harmon? I don't have heated seats or wheel. Currently it's a Uconnect 3C Nav 8.4. I know I need the hub and the adapter cable. I believe I have to get the adapter cable from you right?
Mpgrimm2
Preferred Vendor
SC
5.7L
Harmon 3c RAx radios without AA/ CP were only used in the 2013-17 trucks.
Panasonic 4c UAx with AA/CP were used in 2018 & 19-21 classic trucks
Average J0e
Nebraska
Here's the pic of the unit. It's out of his 2019 Big Horn. I'm not going to use his bezel as I have dual climate controls. Was planning on swapping the screen and radio.
333034499_737515877753237_6634160797959260173_n.jpg334031924_1849379235445291_1105708428720873264_n.jpg336738697_1528065830937384_234933121144261708_n.jpg333431799_168560652704801_3268611100638030706_n.jpg332251048_5985921901535050_3838130231972487956_n.jpg
Mpgrimm2
Preferred Vendor
SC
5.7L
Yeah, you might be able to get that 2 piece unit to work but I don't recommend/support it since it's for a new body style truck. Jimmy07 has a thread where he was working on getting it going... Can't remember what the issues were, but he had some notes there that may help. My suggestion is sell it and get a single piece Panasonic 4c from a 2018/classic
Average J0e
Nebraska
I haven't bought it yet. I'll keep looking! Thank you for your help!
Harry O
Valencia, CA
Installed an eBay 2018 RAM 1500 UAS radio (App Ver 22.66 & Soft Ver 22.32.10) into a 2017 Laramie with an eBay Compass USB hub and a USB conversion harness from MPGRIMM2 (which was an extremely easy transaction, Thanks!) Added a wireless Carplay adapter as well.
eBay Jeep Compass USB Hub - $19.99
Amazon Warehouse Wireless CarPlay Adapter - $56.62
Everything works great with the exception that the radio always resets the presets. It does it sometimes within hours or days, totally random. It remembers my favorite songs but reverts the station presets only. Also, the radio always "updates the Sirius subscription" on startup. I've left the battery disconnected for a day with the same result. I've also sent a Sirius refresh signal as well with no difference.
The eBay radio was one of the batches that had the adhesive that oozed out. I was successful in cleaning it and the touchscreen works well but the marks of adhesive show when there is a light background. I may end up changing the touch screen at a later time for appearance sake.
If anyone has a solution to the radio presets, I'd appreciate the info.
Edit: Pics & links added
HK1837
Australia
I ordered a new screen off Ebay, reasonably easy to change but geez that glue out of the old screens is sticky - gets everywhere, and hard to clean off you and anything else it gets on. Just have to make sure you get the right SL(03) screen not the older SL(01) or SL(02) ones. Here is an example:
Harry O
Valencia, CA
I think I may have solved my Sirius radio presets disappearing.
Cut to the chase: Save your seat memory position after installing the new radio and putting your Sirius presets.
I recall that in my old Durango, my wife somehow changed my radio stations and had her key tied to my seat memory one. Which when I pushed the memory one button, all my settings changed until I figured it out and rejoined my key and radio presets to seat memory one.
With this truck I use remote start 50% of the time and I didn’t track the random preset loss earlier based on remote start or push to start.
I think the key attached to the seat memory position which is tied to the radio presets was loading a default or previous radio owner’s presets.
Since I re-memorized the seat one position, everything is retaining with multiple push to start & remote starts.
If someone had a similar problem, please validate my hypothesis.
If I’m late to the party and I’m the last to know, my bad lol.
Edit: Simplified answer added
PaleFlyer
Charlotte NC
yeah, I did the "clean" on mine last year, and about 3 months later in the Carolina sun, the screen picked up a dead column. Also, the snot is all down the front bezel. Made the trailer controller install much stickier than it should have been... Just had an SL03 screen come in Monday, (Due tomorrow), planning to probably do the rude thing to the truck (again) on Frid.... Well ****, it's supposed to rain the whole next week. I don't like working on the truck in the rain, as the wife has the only car spot in the garage, and we have one of those stupid "split" garage doors that barely let a crossover in, let alone a full size truck.
HK1837
Australia
Just watch that antenna wire attached to the frame when you are pulling it apart, easy to damage it is so small. There is a good youtube video of the screen change process.
UGARAM
Georgia
Thanks everyone for the information, it has been a huge help.
I have one quick question, I am looking to upgrade my 2016 Uconnect to the 4c for Apple car play.
What’s the difference between a 683 model and 684? Did I miss something on this thread.
I see some the initial post says to stay with a 683. However, some post people are saying they are using a 684 model. What am I missing?
18harvest
huntsville
Either is fine as long as it's a ram specfic number.less likely to give trouble.
PaleFlyer
Charlotte NC
I had done it, and when I did the screen last week, something in my head was like "Don't just rip the frame off the radio!" Did the swap, looks way better, but at the same time, the SL(03) screen seems a little "worse" for some reason. Might be it's reflective, and I had gotten used to the "goop-less" screen of the SL(01).
Bobathian
Washington
I've got a 2014 Ram Sport with the 8.4 Uconnect Alpine 9 speaker system Came out of Canada. Could somebody let me know which model number I would need to get in order to add Android Auto? I'm finding lots of used ones online, but not sure which would work for me. Seems to have varying numbers of inputs and such on the backs of them. Thank you very much.
EagleChief
Oklahoma
2014 Big Horn
Man, I just wish the prices would come down already. These radios are now going on 4-5 years old and still $1000+.
Mpgrimm2
Preferred Vendor
SC
5.7L
Used ones shouldn't be that expensive but they are !??
RamForum vendor @AllMoparParts.com can source them for you also... ~ $1200 - $1600 New
All Mopar Parts << click the link to get to their vendor section and sign up/message them though the forum for possible discounts & get ETA/verify availability. Click their Forum avatar.
2018/19 classic 4th Gen Ram Radio: (USA)
68331631Ax (UAQ 4c Nav) ~$1580
or 68331635Ax (UAS 4c non-nav) ~ $1380
2020/21 classic 4th Gen Ram Radio: (USA)
68461699Ax /68528238Ax
(UAQ 4c Nav) ~ $1300
or 68461703Ax/68528242AC (UAS 4c non-nav) ~ $1145
OasisNinjaBat
