INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
Dodgetk81
14 ram 5500 68224525aa vp4 na
Version 13.10.5
R.L.K.
Bristol , Tn.
Sent from my SM-G900V using Tapatalk
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Dodgetk81
Sorry, I was posting the info. I thought someone was collecting for a database. I may have mis understood
R.L.K.
Bristol , Tn.
Lol , it helps with the confusion , if you copy the post requesting the info.
With your post with the info .
LOL my offer of $400 still stands !LOL
Avgas
2015 Express
3.6 Pentastar
Are you looking for an RA4 ? I have an extra one that I'd be willing to sell you.
Sent from my HTC One_M8 using Tapatalk
R.L.K.
Bristol , Tn.
No Sir , I was just messing around , thanks though .
Mpgrimm2
Mpgrimm2
SC
5.7L
Version 13.10.5
You sir are correct. Have you installed the Ra4 yet and verified everything works correctly on the earlier Fw?
If so I will go ahead and add it to the list.
Sent from my LG G4 on Tapatalk.
Dodgetk81
I hooked it up to make sure it all worked, but it's not installed yet. Waiting to talk to harness connection and for my steering wheel controls to come in. It all appeared to work, except for no volume. Hopefully that will fix itself with the steering wheel controls.
Mpgrimm2
Mpgrimm2
SC
5.7L
Do you have the conversion harness and bezel yet?
If so the volume controls should work.
Dodgetk81
Bezel is ordered. I left a message for harness connection to call me. Hopefully I'll have that ordered tomorrow.
Mpgrimm2
Mpgrimm2
SC
5.7L
Is there a particular question about the harness you have?
Dodgetk81
I currently have a 4 speed fan and I'm going to the 7 speed. Do I need the 4 speed harness or the 7 speed? I plan on mounting the module in the factory location. Do I need the regular or extended harness? And finally, if I sent my
68048906AA Harness to him, would he prep it and integrate it into the other harness?
R.L.K.
Bristol , Tn.
You'll need the 4 speed extended harness Sir .
Mpgrimm2
Mpgrimm2
SC
5.7L
RLK took care of the first question, but CuylerTech will have to determine if he wants to prep the other Fan Power harness for you. With the amount of harness orders he has, I would be surprised if he would do that but it can't hurt to ask.
It's really not that hard to do once you have it in your hands. Have you done any basic electrical/auto work before?
One of us will surely be available to answer questions for you when you get around to it on your own.
Dodgetk81
Maybe once I have all the parts in my hands I will understand a little better. I'm fine doing the work.
On a side note, does anyone personally know CuylerTech? I have called and sent an email and have not received a response. I was just looking to see if they were in stock and when I can expect it. Before I lay out the $90 I want to make sure it's legit.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
It's legit, I've bought two harnesses from him.
