INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
So, I got My 2017 RA4 with Nav in yesterday, and I can say I am mighty impressed.
One issue though...when turn by turn voice commands come on, it is not fully muting the music playing, and You can't hear the voice prompts. Any suggestions?
Dodgetk81
My 16 does not mute the music. When the nav is talking you can adjust the volume. I'm sure there is a way to adjust in the settings too, but I have never done it that way.
Booms
The OG
Ocala
2015 Express
Yeah, I saw the setting for the voice prompts volume....maybe I'll try to just turn it up. Thanks!
R.L.K.
Bristol , Tn.
I set my Nav volume to 20 , it lowers my music slightly and speaks at #20 volume until changed . 20 is pretty high imo , I typically listen to the radio @ 14 -18 , for me this set up works well .
I have a 2015 RA4 8.4NA radio in my 14 Ram.
Hope this helps !
Booms
The OG
Ocala
2015 Express
Thanks RLK....
Next problem... can't get my music on my phone to come up as a menu on the RA4....I can play the music over Bluetooth when I initiate it from the phone, but there is no actual menu on the radio. Hmmmm...
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
2 things, the radio doesn't lower the volume of music, it outputs NAV volume on driver front speaker but leaves the music volume the same on all other speakers. When connected with Bluetooth, you will only see information for the current song. There won't be a list of selectable songs unless the phone is physically connected and/or you use a USB/SD.
Booms
The OG
Ocala
2015 Express
Dam....my leased base model corolla has a Bluetooth that brings up a complete song list on the radio..... :crazy:
R.L.K.
Bristol , Tn.
I stand corrected Sir .
I used Nav this morning and you are correct the music volume doesn't lower at all the Nav sound is only displayed through the drivers front dash speaker at the preselected Nav volume level , which in my particular case is # 20.
For anyone that wants the Nav voice only ie... music turn off and Nav voice only while using Navigation you can do this :
In radio mode choose audio then adjust the fade to the left front speaker only while your using Navigation.
Hope this helps !
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
2017 RA4 vp4-NA (verified / USA)
Courtesy of @RebelChief 's new ride.
Pn: 68270661Ax
SW: 16.23.21
Courtesy of @Banjo 's new ride.
Pn: 68270661Ax
SW: ??
Is this what you're looking for?
The part number on my 8.4" RA4 is 68270661AE
@MPgrimm2 here is my screenshot from my 2017 Ram 1500 Sport Crew Cab
------------------- Canadian ra4's ----------------
2017 Ra4 vp4-CA PN courtesy of @TeraNewf 's new ride
Hope this is the info you were looking for
2017 Ra4 vp4-NA (verified/ Canadian)
PN: 68270663Ax
SW: v16.51.19
M² Mods - From my non Flammable S7!
Mpgrimm2
Mpgrimm2
SC
5.7L
And a general reference for those with an Ra3 Vp3-NA radio that had the nav activated but lost after a reset/update...
Just called the company that Chrysler uses for maps on their radios..... took about 30 seconds with the VIN number from donor vehicle.... got the original navigation access code and Navigation is now back on the radio!!!
Company is called H.E.R.E. or a spelling similar ..... phone number is 1-866-462-8837.... they didn't have a menu option for my issue so I just pressed 4 and spoke with someone as if I had an "order" and told the person my issue..... they are Monday-Friday 8am-? Definitely easier to call this company than deal with dealer.... dealer said they had no way of getting old activation code and would require a new one, but Chrysler charges them $550 for that....
Mpgrimm2
Mpgrimm2
SC
5.7L
Need to add this to the other posts about 2016 Ra4 issues ...
2013 Ram2500 - Well folks I verified the 7spd harness was correct. Did the install of all the components to upgrade to the 8.4RA4 radio and factory bezel. Good news is I have heated & cooled seats :happy107:
Bad news is I have no audio what soever on my radio. No FM, XM, Blutooth, NAV talking , Cell audio :-( I see what the volume is set to when I hit the mute button but no control via dash or steering wheel volume controls. ****. Not quite sure where to go from here just yet. Yep I'm all ears...
Well I ran out of time after the install as we had a dinner engagement. (truck sat for 4 or 5 hours) I was a bit bummed having the heated & cooled seats working but no radio volume. I think I had a total of 4 key start stop cycles with the same result (tried NAV but no luck). I came home from dinner and went out to move the truck and Whalaa!!! Houston we have volume control!!!
:happy107::happy107::happy107:
We'll see if tomorrow the radio remembers it worked :crazy: For tonight I'll go to sleep a happy man :favorites13:
And here's a successful 2017 RA4 install in a 2015 truck
So, I got My 2017 RA4 8.4AN installed in My 2015 Express.
All the things that I thought I was going to have a problem with, worked!
Nav works perfect
Turn By Turn in 7" evic
Voice commands
Text to talk
Apps
Tells Me when I'm speeding... :naughty:
Weather and Traffic
However, two things aren't working that perturb Me.
It won't populate a list of songs from My Bluetooth device, and I have no SDcard option available on the radio.
Anyone?
Mpgrimm2
Mpgrimm2
SC
5.7L
Thanks you very much!
Mpgrimm2
Mpgrimm2
SC
5.7L
New update coming out for 2013-2016 radios... Thanks Dan!
See the thread here...
Uconnect 8.4 & 8.4an update - 17.11.07
I saw that on the web, but the uconnect update website only show the 2016 update for my truck now, it will be availble soon I guess:
NUMBER: 08-028-17
GROUP: Electrical
DATE: March 17, 2017
SUBJECT:
RA3 And RA4 Radio Over The Air Software Updates
OVERVIEW:
This bulletin provides information regarding the latest Flash Over The Air update (FOTA)
and provides a service technician an overview of the steps a customer will need to take to
complete the update.
MODELS:
2013 - 2016 (D2) RAM 3500 Pickup
2013 - 2016 (DD) RAM 3500 Cab Chassis
2013 - 2016 (DF) RAM 3500 10K Cab Chassis
2013 - 2016 (DJ) RAM 2500 Pickup
2013 - 2016 (DS) RAM 1500 Pickup
2014 - 2016 (KL) Jeep Cherokee
2015 - 2016 (LA) Dodge Challenger
2015 - 2016 (LD) Dodge Charger
2015 - 2016 (LX) Chrysler 300
2015 - 2016 (UF) Chrysler 200
2014 - 2016 (WD) Dodge Durango
2014 - 2016 (WK) Jeep Grand Cherokee
2013 - 2016 (ZD) Dodge Viper
NOTE: This bulletin applies to vehicles within the following markets/countries:
NAFTA/(U.S. only).
NOTE: This bulletin applies to vehicles equipped with Uconnect 8.4 (Sales Code
RA3) or Uconnect 8.4AN (Sales Code RA4).
NUMBER: 08-028-17
GROUP: Electrical
SYMPTOM/CONDITION:
The following improvements are included in this update:
• Adds Apple Siri® Eyes Free capability for iPhone® owners.
• Auto Play can now be configured.
• Adds do not disturb text message feature.
• The ability to drag and drop icons into the menu bar.
• Fix for radio locks up/frozen.
• Fix for stuck on black/blank screen.
• Human Machine Interface (HMI) improvements.
• Several navigation improvements.
• Fix for radio loses time.
• Charge Complete notification is not received (RU PHEV only).
• Media devices, Phone pairing and Bluetooth usage improvements.
• Improved tuner performance.
• Enhanced Voice recognition (VR) performance.
• Enhancements in Connectivity Apps (Yelp, Pandora, Aha, etc).
DISCUSSION:
All MY13-16 vehicles sold in the U.S. with the RA3 or RA4 radio can now receive software
updates “over-the-air”. Updates to software level 17.11.07 will occur in a phased roll-out.
The software is updated through the built-in cellular modem in the radio which is
connected to the Sprint® 3G network. Customers will see a notification on their radio
screen when new software is available for their radio (Fig. 1). The owner will have the
option to update the radio or schedule the update for later. There is not an option to
decline the update indefinitely. The update must be performed.
NOTE: This is an information only TSB to help the customers understand how they
can perform their FOTA update. This document does not contain a LOP for
reimbursement.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Not sure if I like the OTA...
R.L.K.
Bristol , Tn.
Anyone know how long this update takes to install ?
Also , can one " accept " the update then drive the vehicle while it auto updates or must you interface with it Untill installed while in park ?
Sent from my SM-G900V using Tapatalk
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Now that I think about it, I wonder if they have already been experimenting with the OTA push. Recently my 911 cheater started giving me errors and text to speech stopped working on my non-factory RA4. It has since gone back to normal except for my cellular connectivity is null...
TMFMK
