SitKneelBend
Moderator
Member Relations Specialist
- Jan 8, 2015
- 10,987
- 7,679
- Location
- St. Louis
- 2014
- 3.6 Pentastar
Check ...
Yes, I understand the old hub should work with the new radio. One of the early posts in this thread said Infotainment has a pricey update that would enable the USB ports. But nothing except Bluetooth shows on the media screen, and the USB ports charge, but don’t have any USB functions.
So… I was asking if there is a way to enable the USB without the Infotainment option. I do have an OBDMX+ elm327 that is very good, and a lot of software can be used with it. Can AlphaOBD be used to enable the USB ports, or how would this be accomplished? Ports show up still on my oem radio, 2013 Uconnect 8.4 VP3 CA.
Charlie
That post is the AlfaOBD setting to check first. He thinks maybe the setting isn't configured so maybe once you set it, it will read.You will have to explain this post, not sure what it is showing me, but it looks like a drop down menu in an app…
Charlie
