Install of oem tow hooks on a 14 Express
JIMBOX
:) It's a rubber spool/w fat washers on the down side 2" x 1-1/4/w 1/2" sleeve thru the rubber doughnut--
It's kind of a one use fitting, maybe available at a dealer --parts department-
Whatever
:crazy: JIMBO
R.L.K.
R.L.K.
Bristol , Tn.
Ugh. I tried to save money and bought used tow hooks. They showed up today and they're missing the rubber bushings from the back, which aren't sold separately. Wonderful.
Damnit ! Well ?
Sent from my SM-G900V using Tapatalk
R.L.K.
R.L.K.
Bristol , Tn.
From the way it looks, I think you would have to actively remove them from the hooks.
If I had the dimensions I might be able to find one online that would work.
I bought them from a yard so I think I'm going to give them a hard time about it.
You are correct Sir , one would have to remove them on purpose. .....give them.a hard time !
00R/T
CT
I'm going to take some measurements tomorrow and see if I can find something close. I'm not really sure why it's there, but there has to be a reason they wanted an isolator there. Otherwise I'd just stack washers.
JIMBOX
:) I gave you measurements and the rubber spool isn't pressed into a hole--
It snaps into a slot at the end of the tow hook-
did you call the dealer parts dept ??
:crazy: JIMBO
00R/T
CT
:crazy: JIMBO
Yeah, the part is not available separately for some reason. I'm going to try to find one in the dimensions you listed, but I figured I'll take some measurements to get a range of what might work well enough if I come up empty.
JIMBOX
:) Yeah, good luck !
Remember I said the rubber part of that bushing is a "SPOOL" that SNAPS into the end of the tow hook and the SPOOL center dimension is 1-1/2"-
Since the FRAME mounting of the hooks absorbs the majority of the FORCE, when applied---I'd just use a 1/2" spacer--metal/rubber/plastic--because you'll probably never find a bushing LIKE THAT any where-
Good luck
:crazy: JIMBO
JIMBOX
:) Outstanding day--
Thanx again Kenneth for the tow hook brackets--they just arrived and look so professional, they autta install themselves :roflsquared:
I'll probably have time to set em up by Sunday/w pics-
Thanx again Ken !
:crazy: JIMBO
Ken226
Washington State
Very well made, figured I'd post a picture of them unboxed. You can tell Ken takes pride in his work.afc2e5e0c3095b00cbd6a07228e122ef.jpg
SitKneelBend, do you mind if I use your photo to list the last couple sets I have on ebay? I've already got them boxed up and forgot that I havn't taken an ebay photo yet.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Dude not at all. I'll even write a testimonial!
R.L.K.
R.L.K.
Bristol , Tn.
:) Yes sir, thanx to Ken226--MY HOOKS IS IN !
Thanx again Ken !
:crazy: JIMBO
Very nice indeed Sir !
Good idea on the holes on the ends through the plastic
R.L.K.
R.L.K.
Bristol , Tn.
Damn! That looks good. Very Cool!
I got 1 of the last 2 sets up on eBay with SitKneelBends pic, and one of my own. A test to gauge interest.
Good luck Sir !
Please take a look at my OP here , if you'd like me to remove the mention of you and your brackets just let me know .... sorry I didn't ask your permission prior to my edit .
http://www.ramforum.com/showthread.php?p=1125823
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I think there will be a great deal of interest. Be sure to throw sport and express in the description to get hits on eBay. I know you gave us a great deal on these, but you could easily sell these in the $50 to $65 range...
00R/T
CT
Without a doubt.
00R/T
CT
So, who's making the template for the trim cutout? [emoji16]
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I was thinking about figuring out that when I redo mine and posting that here. I already had my hooks installed, but this bracket will place them in a much better location and allow easier access around my Lund bull bar...e5991f0db68b8e3fae7a29d2f6b93cf3.jpg
Ken226
Washington State
TMFMK
