Install of oem tow hooks on a 14 Express
ulemon
Iowa
Hey I called up my local metal fabricator and he was wanting a '.dxf' file format since that is what his cad software used, does anyone know if there exists a '.dxf' version? Or if anyone is still selling them?
does anyone know the towing specs with these brackets? e.g. 10,000 lb or whatever, I was looking to get a 12,000 lb warn winch so I was wondering if these brackets would be okay
I managed to answer my own questions:
According to the Amazon listing these tow hooks have a capacity of 5,500 lb each
I also managed to convert the cad files to '.dxf' format for my local fabricator's machine. I made dxf files for several years since I didn't know the age of his machine. I put in dxf files for 2000, 2004, 2007, 2010, 2013 and 2018 (and 'R12 LT2' whatever that is, I think its super old but I don't know which year that corresponds to) so hopefully these can help someone else who needs dxf files
DXF files location 1:
Google Drive
DXF files location 2 (incase the first link doesn't work):
Mega Upload
Rasworld84
Cleveland, TN
emails outbound
Emails outbound. If its not in your inbox, check your spam folder.
My email address is from the ancient Microsoft Network, which no longer exists. Grandfathered in by Hotmail, as such it ends up in the spam folder a lot. If you don't see it in your inbox or spam folder at all, verify that you sent me the correct email address, as typos do sometimes happen.
O
Thanks to @Ken226 I was able to grab his pdf files, scale them on the printer, and use them as a template to create my own brackets which worked out perfectly. It took $50 worth of carbide blades and at least 4 hours of my time to work the 3/16" angle iron with saws and a drill press, but in the end turned out exactly as I had hoped. Used OEM hooks from ebay which I sand blasted and repainted. Thanks to everyone on this thread for paving the path !
tmCjCxDanaEk8bVG7
You did a great Job! How did you get the template print outs at full scale?
Uncle Damo
It was trial and error. I printed at a zoom level then measured on the print until an 8" dimension actually was 8", as an example. Once that was calibrated it all fit perfectly.
Martin1500
Alberta, Canada
Thank you so much to @Ken226 for designing the brackets and the rest of the crew for useful tips. Just finished the install.
ric221
Looks good. Just a quick question, how hard was it to get that plastic piece out of the Sport bumper, does it push out from the back or pull out from the front?
Martin1500
Alberta, Canada
Thank you. It was probably the most time consuming part. You need to loosen the retaining clips from the back and the to push the whole thing into the bumper cavity. There is not much space to give, so you have to twist it and then pull it out through the front. I hope that makes sense.
I opted to space the holes 6 inch apart in order not to obstruct the hooks in case of the bumper removal.
EViS
United Kingdom
What tool did you use to cut the trim opening straight after drilling?
EViS
United Kingdom
I sent the drawings (PDF, DWG and STP) files to a couple metal fabricators. However, they advised that the design would not create a neat fold after cutting. Particularly, where the end tapers off, this would roll over during the folding process. Instead, they recommend cutting the individual components and welding the bracket sections. Has anyone else come across this advise? Would welding the individual bracket components have any detriment over folding?
Uncle Damo
I started with angle iron, see this post #390. https://www.ramforum.com/threads/install-of-oem-tow-hooks-on-a-14-express.73872/post-2469600
EViS
United Kingdom
Thank you very much to all who have contributed to this thread, particularly to @Ken226 for all the work he put in to sharing his bracket design and @16WhiteQC for sharing his install images and tight cut-out dimensions.
For anyone else wanting to undertake this install in the future, here are my notes from reading the entirety of this thread plus many others.
Tow Hook Bracket Drawings: These are designs created by @Ken226 and consist of PDF, DWG and STP files. "These move the front of the hooks up, and outboard enough that they are centered in the lower grill area of the 2012 and up Ram models that have the plastic painted bumper, such as the sport and express."
ASTM A36 Carbon Steel: Commonly called mild steel, is the correct material to fabricate these brackets. The thickness should be 7 guage (7 ga) which is 3/16". I opted for 5 mm thick steel, which is only marginally greater than what is specified on @Ken226's drawings.
Other steel designations are 1018 cold rolled or 4130 / 4140 chromoly alloy. If you're fabricating these brackets yourself out of one piece of angle iron, you want to start with a section that measures 3" x 3" x 3/16" (x 8" length) ((76mm x 76mm x 4.76mm (x 200mm length)).
I found a local steel fabricator who could manufacturer and powdercoat the brackets from @Ken226's 3D model step file. However, during production, they did run into an issue with the folding of these brackets which resulted in them deforming as follows.
To overcome this, they cut the base and back profiles separately, then welded them together to achieve the correct geometry.
Lower Bumper Insert Trim Cutout: I followed @16WhiteQC's cutout specifications which resulted in an incredibly neat and almost factory finish. I almost blindly followed his profile dimensions and can confirm that they are absolutely perfect.
Inward distance from end of lower rib: 4 7/8" (124mm)
Cutout opening width: 2 5/8" (67mm)
Cutout opening height down from lower rib: 1" (25mm)
I recommend removing the insert trim from the bumper and making the cutouts on a bench. You will need to remove the trim later to install the hooks through the small cutouts.
I cleaned the cutout area, adhered masking tape, then drew the cutout shape. I drilled two 6mm holes in both lower corners of the cutout to achieve a rounded internal corner. During cutting, I heated the utility knife blade between passes as this immensely helped keep the cut neat. I then removed the tape and polished the cut with some 400 and 2000 grit finishing paper.
Mopar Front Tow Hook Installation: Installation procedures are pretty straight forward with tightening torques being 95 Nm (70 ft lbs) for the four bolts against the bumper and 85 Nm (63 ft lbs) for the single bolt at the rear of the tow hook.
To install the tow hooks through the small cutouts, firstly re-install the insert trim back into the bumper but do not clip it into place. Then position the hooks at 90 degrees towards the bumper and manoeuvre the hook ends through the cutouts. It helps to have one person underneath the truck and one person in front of the bumper to pull the hook through whilst gently pushing on the insert trim. Once the hooks are loosely bolted in place, clip the insert trim back to the bumper.
Finally, align the hooks into the cutouts and tighten the bolts. @16WhiteQC posted in his thread that he had to "add a 1/8" x 1" flat stock spacer to move the hooks down a bit due to the feature in the insert". I confirm that I also had to do this otherwise the hooks were pushing up against the insert trim's lower rib. I used two M12 washers between each hook and bracket (i.e. four washers per tow hook). In hindsight, I should have asked the fabricator to move the two holes on @Ken226's brackets upwards by 3mm which would have negated the need for additional spacers.
Oh yeah, before all of this, I had my tow hooks powdercoated a metallic red colour to match the Factor 55 Hitchlink receiver at the rear :cool:.
16WhiteQC
Hudson valley, NY
View attachment 571451 View attachment 571452
View attachment 571455 View attachment 571453
Looks great!
pginny
NY
I'm looking to add tow hooks on my '17 Express . However, I'm having a tough time finding the brackets. Ive asked around multiple machine shops and none have been able to fabricate them . I do not have the means to create the brackets myself, I was wondering if I can use the oem brackets or if someone has anyone I could order from using the design y'all provided?
Thanks in advance
phorrestphire
