Instrument cluster lights comes on by itself
Ron Seniuk
Winnipeg
I have a 2017 Ram 1500 5.7l Outdoorsman and have been having trouble with a dead battery. Found the culprit, but no clue where to go to solve the issue. The culprit is my instrument cluster waking up almost every other minute or so. I saw a thread about the radio software waking it up, but when I threw my VIN into the UConnect website it said I was up to date. I've pulled the BC fuse in the hopes of resetting it, but to no avail. If anyone has some areas to look into before I start having a mechanic begin to drain my bank balance I'd very much appreciate it.
TYIA
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
TYIA
Do you know which radio you have?
Ron Seniuk
Ron Seniuk
Winnipeg
I haven't looked up the numbers but this is from the system settings.
RamCares
n/a
n/a
TYIA
Feel free to DM us with your VIN! We can check for any existing updates or documentation for your concern.
Chris,
Ram Cares
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Pretty sure there are 2 fuses for the radio. One is an inline fuse along the drivers side of the firewall in engine compartment. I may be mistaken but pretty sure I recall that being discussed at some point.
Did you try doing a hard reset on the radio? Use the search function above to find the procedure.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
You can find the latest (and last) firmware for your truck in @Mpgrimm2 's post here...
Here's the direct download link from his thread.
- Ra3 VP3-NA My13-17 v18.45.01 Fw update Link. (official uC Update 1 11/1/19)
MD5: DB071D0E5598D0F1C80ED6E8082B3B10
Adamcr68
Lorton VA
Hemifever 5.7
My 15’ has that inline fuse, under the brake master cylinder, just to make sure it’s hard to get to.
Lee Peterson
Hamilton ON Canada
3.6 Pentastar
Somethings waking up the canbus. I've seen videos of the hvac module doing it and the brake ABS doing it.
TradesmanGuy
Marine Corps
PNW
PentaStar V6
There is a lot there to try. Have fun!
