Intake manifold swap
John Darsey
Has anyone done the 4g 5.7l to 6.4l intake manifold swap on there truck before? Curious to performance review and ease of install
crazykid1994
Lots of people have done a 6.4 manifold swap onto their 5.7. It’s a super easy bolt in swap. Only need to extend the brake booster vacuum line. I would buy the srv harness extension with the manifold to make it even easier otherwise you need to splice the harness to extend it. I even have a way to install a catch can into the manifold if you choose to do that. I purchased a stock 6.4 air box to go with my swap to keep everything 100% factory parts
https://www.ramforum.com/threads/6-4-intake-manifold-swap.163727/
Jwithing
STL
Definitely recommend the mod as theres a noticeable difference. I could only peel out my 37s just a little bit beforehand. Now I can keep it going a good distance qnd go through my expensive rubber quicker if desired. :p
noraa73
