Can you list your new system plan? What are you getting for that money and what do you want out of your system? More details on the equipment and the complexity of the install would help.
As for the quality, CD quality is much higher res than anything you would ever stream. Pandora and the like are 2/3 CD quality at best.
So this is what I typed out to send to the best buy guy. I also have another thread I started months ago when I was beginning the purchasing portion of the system. About a 2 minute read below.
Focal 6.5, tweets, and 4 inch for dash. (doing away with the 6x9 for rears most likely) (slight trimming in dash to fit 4 in speakers is required I do believe)
Focal 6x9 for rear ????? (have them, not sure if I'm supposed to use them)
Speaker adapters to convert 6x9 to 6.5 (may be too thick)*
3 arc audio amps ( (2) 300.4, (1) 600.2)*
Arc audio ps8 with controller (needs firmware updates and such) (controller to be mounted somewhere to look factory. also has 3 presets to be tuned, can discuss in person)
180 Sq ft roadkill expert (36 Sq ft of this off brand and used under carpet only)*
36 Sq ft roadkill carpet pad (laid on top of off brand dynamat)
Peel and stick ensolite for everywhere else except under the carpet
Sound deadener to be installed with 100% coverage everywhere inside the cab including pillars with scrap pieces cut from other portions of install. Purchased enough to do both panels for the 4 doors.
Fast rings speaker foam for around 6.5's
1/0 gauge power wire for everywhere (includes going to all amps from distribution blocks with rings/reducers, some of which will need to be grinded down to fit)*
1/0 gauge for big 3,4,5,6? wire upgrade*
Heat shrink for ends of all wires/connectors*
150 ft 16 gauge speaker wire for all speakers*(ran true from amp all the way into speaker terminals/connectors - not using any factory wiring)
20 ft 12 gauge speaker wire for subs*
Emblems/lettering for sub box and amp rack with 3m tape (Ram Head and Letters R.A.M. x 2)
Stinger fuse holder*
Wire loom (will have this on wire upon arrival to help save time)*
Led interior light/license plate bulb kit
May swap out to a better battery as well if I find one that will fit in factory location. Do not want to add a secondary.*
I will need carpeted seat spacers and amp rack built. The seat spacers intended for this box are 1-1/2 inches tall, and when installed create the "back seat mod" for free!!! Ha.*
