Lifter Failure / Hot Oil / Better Cooling etc.
Black1500Ram
Black1500Ram
Scottsdale, AZ
If you are sure the lifters have an issue, replacing them is the only fix. The cam lobe has either delaminated or a lifter has a roller or roller bearing failure. Pull the valve covers and look for slack in the valve train. Don't wait until you have more damage and send more metal through the engine. You will not reset the valve lash as these engines do not have an adjustable rocker setup.
I don't know why you are running "0" weight oil in a hot climate.
I replaced the lifters and oil pump with the Mellings products. Very good replacement parts. Used an OEM VVT Mopar cam, deleted the MDS system and plugged the solenoids. Added a tune and shorty headers while I was making these repairs to eliminate future exhaust bolt issues. If you want to keep the MDS system, do it because the MDS lifters/system are not the cause of the lifter failure. I lost both MDS and non MDS lifters in my engine. I pulled the oil pan and windage tray to clean the bottom end of any metal debris.
Changing cooling fans will not lower your operating engine temps until you get more airflow or set the electric fans to operate at a lower temp. My 2013 (5.7) has both electric and mechanical fan. I installed a 180 thermostat. Engine runs at 192, even when towing.
Typo, I’m running m1 fs 5w40 euro.
Yep, same for me. I mentioned it because I'm interested in the physics, as to what exactly is going on that would cause a lower psi, and it appears from my 10 second search above that not every oil cooler loses pressure (nor would my limited understanding of this subject suggest that it should lose signifcant pressure). Something odd going on somewhere.
Flow rate is basically the same principle as voltage drop.More turns and passages the bigger the drop.The only gas powered Chryco that runs an oil cooler is a Hellcat and it runs a higher volumn pump to maintain the flow rate and pressure. Water/fluids and voltage don't like line length or bends in the line
Here's some reading on the subject .
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Yup. Newtonian Physics has amazing analogies between fluid, electric, and heat. Makes things easier to comprehend.
Then there's quantum physics. I couldn't take anymore after a single introductory dose of.it.
Black1500Ram
Black1500Ram
Scottsdale, AZ
Yup everything flows from high to low and all in between is a restriction.
I personally have a hard time buying into superposition theory and the whole matter exists in multiple states until observed… I just feel like we (humans) have yet to truly figure out what’s going on .
Black1500Ram
Black1500Ram
Scottsdale, AZ
Does anyone have any recommended places to buy oem Mopar parts from?
I’ve looked into moparfactoryparts.com,
Moparpartswholesaledirect.com
Any good experiences on eBay?
eBay lifters
akordboy
US
I just picked my ‘14 up from the dealership because of the tick with 86k miles. The lifters were bent, cam shot and when they took the head bolts out a chunk of the head fell off. My dad always told me if you’re gonna do something do it right. It took almost a month to get the heads in and final cost was just under $7000. Luckily I only had to pay $100 thanks to the warranty.
John Schmidt
Snowbird - USA
5.7L Hemi w/FLOWMASTER 50 SERIES DELTA FLOW
Hi Guys,
Been lurking for a while and now have the dreaded lifter tick.
Thanks for everyone who has replied to my prior questions. Please anyone feel free to jump in correct any misinformation I might have, suggestions etc.
MY TRUCK
2015 Ram 1500 5.7, 8HP70, 3.92 rear. Bought at 27k currently 112k
Oil related maintenance:
5w20 PUP w/ fram xg10060 filter changed every 5k during that time.
Currently M1 FS 5w40 w/ Fram xg10575, Purolator One Air Filter changed once a year (shout out to project farm on Youtube)
Other maintenance / upgrades:
Spark plugs changed at 100k, Amsoil in trans, tcase and diffs. 89 fuel. Suspension fully rebuilt will all Moog parts, Hellwig rear sway, Freedom Offroad Rear control arms and track bar, Billstein 5100's yada yada v6 fan in addition to mechanical.
Heaviest tow - ~6000lbs camper with dist hitch... maybe 4 times / year
So now that I have 'the tick' I'm putting together this thread for what I'm going to do to fix it and hopefully compile some other preventative fixes to reduce the chance of it happening again? Its def lifter, I've had the exhaust manifold tick; this is nothing like that.
My truck is almost paid off so I don't want to have to buy another one any time soon, and would like to get to 200/300k miles. If money allowed, I would just trade in my truck for a 3500 and call it a day but it doesn't and I don’t need a 3500.
START HERE TO SKIP INTRO
Plan is to replace lifters with the latest 2017+ OEM version, still MDS, new MDS cam, pushrods, head studs.
I also plan on installing new oem water pump, 180° t-stat, new timing chain tensioner, hellcat oil pump (stock 50 psi spring), Royal Purple 20-820 filter, remove center AGS shutters, caulk transmission heater bypass, Pacbrake Oil Filter relocation kit.
I noticed while towing a quad on a small 5x8 single axle trailer (<1200lbs) through route 87 mountains in AZ, 100° ambient, I'm getting into the 250° oil temp range with cruise set at 65. Coolant is still at 210°, trans gets up to 200° sometimes. I can’t go more than 45/50 mph over the same route with the camper without the temps creeping into the 260° range.
Anything I'm missing guys? I'm furious that I have to do this but if I'm going to tear into the engine I want to give this truck the best chance to last another 150k miles.
Thanks in advance.
James
I seem to recall that Johnson makes lifters for the 5.7 that are better than OEM, in terms of lubrication (I think they call it axle drilling) ... helps with the lifters being mounted so horizontal-ish on the hemi. Supposedly addresses the hemi tick.
Might want to check that out.
- John
Roy the Fixer
Lake Mary, FL
I'm not seeing the other usual suspect for hemi tick mentioned here. My last Ram was a 2012, and I noticed the tick at about 108k miles. I studied it and came to realize that it was load sensitive! Lifter tick is not load sensitive, although it can change with rpms. My tick was a broken bolt on the right exhaust manifold and was easy to mistake for a lifter tick. Two theories for why the bolts break are that the manifold gets stressed because the temperature is unequal when she is running on four cylinders in Eco mode, and that the manifold mountings get stressed by the exhaust pipes being mounted too rigidly causing mechanical stress as they grow longer when they get hot. Anyway, I drilled out the broken bolt, bought new gaskets and bolts from the dealer and slapped her back together; no more tick! So, proceed with caution before you spend time and money on the cam and lifters; about $50 worth of parts and a little cussing fixed mine!
- John
The Johnson lifters aren't for a stock oiling system,that lifter leak has caused a few blown up hemi's,as the oiling system isn't set up,to handle another leak,which is what the axle oiling hole is.Go onto a few of the Hi-po Ram facebook pages and ask about them.
Black1500Ram
Black1500Ram
Scottsdale, AZ
My tick was a broken bolt on the right exhaust manifold and was easy to mistake for a lifter tick. Two theories for why the bolts break are that the manifold gets stressed because the temperature is unequal when she is running on four cylinders in Eco mode, and that the manifold mountings get stressed by the exhaust pipes being mounted too rigidly causing mechanical stress.
Hi Roy,
Thanks for the reply but I don’t have broken exhaust manifold studs. I’ve had that before - that’s an airy sounding ticking. This is a metallic tapping sound. Think tapping a wrench on your toolbox.
Also the header bolts breaking has been discussed as dissimilar thermal expansion rates of the cast manifolds to the aluminum head.
Black1500Ram
Black1500Ram
Scottsdale, AZ
@Wild one what are your thoughts on Johnson lifters with an unmodified hellcat oil pump? (70psi) I was planning on installing one with the oem 50psi spring with oem lifters.
I still wouldn't run them,the oem lifters aka Hellcat lifters with the idle bumped up to 750 rpm is your best bet,even with the hellcat pump.You still need crank splash to help lube the lifters,and a higher idle is one of the best things you can do to help prolong the life of the lifters.
Black1500Ram
Black1500Ram
Scottsdale, AZ
I’m planning on keeping the mds system, and was really trying to avoid having to pay for a tuner / tuning but I may… no other way to raise the idle speed right?
Lifters, cam, pushrods, head gaskets, arp head bolts, oil pump, water pump, tstat, trans heater bypass, AGS delete, all this stuff adds up for things that IMO should never need to be done on a stock power truck, doing stock truck things.
If I were hunting power then I’d have no problem paying for tuner, tuning, long tubes etc.
Sigh
Lifters, cam, pushrods, head gaskets, head studs, oil pump, water pump, tstat, trans heater bypass, AGS delete, all this stuff adds up for things that IMO should never need to be done on a stock power truck.
Sigh
I'd do ARP head bolts before head studs,lol. Studs are a royal pain to work with,and unless you're planning on hitting it with 10+ lbs of boost or a 175 shot of nitrous,aren't really needed.The ARP head bolts in my truck have been holding a 75 shot of nitrous for 600 dragstrip passes with no issues,lol
Black1500Ram
Black1500Ram
Scottsdale, AZ
Yeah I meant bolts. I had arp bolts in my bmw 135 n54 engine making 600 whp… never had an issue.
