LIGHTING
shaker
md
Ok folks, here we go. I have had a message saying my right brake light is out. NOPE. I had a front right low beam go out. I replaced that. Being ****, do 1 do both. I cracked the left front housing fighting the ball socket to remove. Filled up like a fishpond. I then started getting an old school quick flash and message left turn signal was out INTERMEDIATELY !!!. The quick flash on the dash display initiates but the front and rear flash normal BUT the mirror light flashes with dash display.
(side note) A week after I changed the bulbs initially,,,, when going from high to low beam I could hear a plastic based noise/click in the left front AND it looked as though both headlights would bounce when put back into low beam when parked in front of the garage door. no I do not smoke crack but I am SERIOUSLY confused. I replaced the front left assembly. Still have the same turn signal issue.
Any thoughts or willingness to teach me something????
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Op can you describe the vehicle please. Year make model, mods, etc. Understand you have a light problem but difficult to help if we don't know reflector vs projector, bulb type, regular, led, hid, etc. Any mods, is it a laramie or Tradesman, etc.
Thanks
tron67j
Maryland
See questions above
